Old 07-25-2012, 06:47 PM   #15
Gen
Drives: Scion FR-S
Originally Posted by deedzman View Post
when im moving at a constant speed at say 5mph i dont need to be using the clutch right? I feel somewhat jerkyness from neutral at a stop to 1st because of my inexperience with manuals but when im at a constant speed I dont really need to play around with the clutch just use the gas I thought?
I was referring more to what would happen in that car as a result of heat soak in traffic. It would buck in 1st as a result.
In general, 1st and reverse are a lot more 'touchy' than the other gears; you have to be a lot smoother with your inputs. You always have the option of moving to second gear as well.
Gen is offline   Reply With Quote
Old 07-25-2012, 06:49 PM   #16
deedz
Drives: Rocket Bunny FR-S
Originally Posted by ngabdala View Post
It just takes time and practice bro. The same thing happened on my first manual car in 2011. You will learn to smoothly let off the clutch while giving the right amount of gas. Also, if the engine is not warmed up it will probably do that regardless of how well you shift.
Yea im still practicing on the stop and go part with the clutch but in this situation my foot is already off the clutch and I am just crusing around the parking lot with only the gas
deedz is offline   Reply With Quote
Old 07-25-2012, 06:50 PM   #17
deedz
Originally Posted by Gen View Post
That's right, but 1st and reverse are a lot more 'touchy' than the other gears; you have to be a lot smoother with your inputs. You always have the option of moving to second gear as well.
1st gear when i let off the acceleration just feels like it wants to slow down bad but I guess thats normal? I do try second gearand 5-10 mph and the rattling from the transmission and sound as if the rpm is too low for the gear and its getting bogged down kills me
Old 07-25-2012, 06:51 PM   #18
Gen
Drives: Scion FR-S
At parking lot speeds in 1st, you should barely have to touch the gas. Just letting your foot off the clutch and rolling will get you around 5 mph.
Yeah that's all normal. You really don't have to give it much gas at all. To me it sounds like you're giving it too much gas, then letting off, back on gas, etc. which is causing that feeling.
Old 07-25-2012, 07:21 PM   #19
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Sounds like heat soak. S2000s were notorious for doing this in traffic. It was like riding a mechanical bull. I've yet to experience anything similar in the FR-S.
I was in stop and go freeway traffic for about 30 minutes today (100+ temps). I was def heat soaked.
Hawaiian is offline   Reply With Quote
Old 07-25-2012, 07:33 PM   #20
xpicer
xpicer's Avatar
Drives: 2013 frs white out
Completely normal. Is not the car ,its you.
xpicer is offline   Reply With Quote
The Following User Says Thank You to xpicer For This Useful Post:
GenkiElite (07-25-2012)
Oh What A Feeling - Toyota Jump lives on! bestwheelbase FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 11-20-2012 03:02 AM
Like my FR-S, but still like the feeling of my Celica GT-S brieweb Scion FR-S / Toyota 86 GT86 General Forum 12 07-04-2012 06:16 PM
Tomzilla's "That feeling when your car is far cooler than you" BRZ thread. Tomzilla Member's Car Journals 1 06-19-2012 01:10 PM
Why are most stock wheels weak stance? #87 Other Vehicles & General Automotive Discussions 16 12-17-2011 06:15 AM
Anyone feeling amped up? NemesisPrime909 Scion FR-S / Toyota 86 GT86 General Forum 36 08-04-2011 08:49 PM
