Old 11-08-2020, 09:45 AM   #1
redwine
8" lift enough for GearBox/Diff oil change ?
Hi,
I hope to change my own Manual GearBox & Diff oil.
Is 8" of lift adequate for access to the Fill/Drain plug ?
My drive way is slightly off,
Front & Rear axle may have an inch of height differences,
Will that be a concern as well.
I'm small build & BRZ is stock.
Thanks
redwine is offline   Reply With Quote
The Following User Says Thank You to redwine For This Useful Post:
humfrz (11-08-2020)
Old 11-08-2020, 03:21 PM   #2
Originally Posted by redwine View Post
Hi,
Thanks
The 8" lift should allow you enough room to get to the drain and fill plugs. It would help by knowing where they are to start with.
I reckon the 1" height difference of 1" isn't going to make a significant difference.
Old 11-08-2020, 06:19 PM   #3
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
I'm assuming they are concerned about lifting the car on four jack stands on a slightly sloped driveway. I would just lift the front for the tranny and the rear for the diff fluid changes.
I myself have been wondering about this and even though the slope on mine is minimal, the idea makes me incredibly uncomfortable. I only lift front or back on my driveway.
Plumbus is offline   Reply With Quote
The Following User Says Thank You to Plumbus For This Useful Post:
humfrz (11-08-2020)
Old 11-08-2020, 07:23 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I assume this is with wheel chocks in place?
The Following User Says Thank You to Spuds For This Useful Post:
humfrz (11-08-2020)
Old 11-08-2020, 07:34 PM   #5
Good point.
I thought he was more concerned with having enough space under the car to do the work and whether or not the height difference would make a significant difference in the fluid levels.
Back in the day, the jack stands (concrete blocks and pieces of 4"x4"), were less of a concern than the jacks we used.
(ask ol @Tcoat how many times he had a car slip off one of those jacks) -
Tcoat (11-08-2020)
Old 11-08-2020, 07:41 PM   #6
well of course use wheel chocks, silly -
Spuds (11-08-2020), Wally86 (11-10-2020)
Old 11-08-2020, 08:28 PM   #7
Good point.
More than I ever care to remember.
humfrz (11-08-2020)
Old 11-10-2020, 04:07 AM   #8
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
Seriously, save the money and buy a QuickJack. Best money I spent on tools.
SUSPECT_BRZ is offline   Reply With Quote
The Following User Says Thank You to SUSPECT_BRZ For This Useful Post:
Old 11-15-2020, 04:32 AM   #9
redwine
Thanks for all the inputs.
I'm thinking to custom make 4pcs of Ramp (8") from High Impact Foam. They are really light & i suppose they are easier to work with than wood.
Of course will also have another safety backup.
gearbox and diff oils danielmailrs Engine, Exhaust, Transmission 9 11-21-2018 08:50 PM
Diff Gear Change Riftur Engine, Exhaust, Transmission 35 08-20-2016 04:14 PM
Gearbox Loose and "Slushy" Sound When Under 2200 RPMs astrubinger Issues | Warranty | Recalls / TSB 9 07-08-2015 11:48 PM
DIY Oil Change: Brand of oil you use and method you use to jack/lift PPX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-22-2014 12:09 PM
Clutch / Diff / Gearbox issue? doggy Issues | Warranty | Recalls / TSB 5 10-03-2012 11:47 AM
