| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
8" lift enough for GearBox/Diff oil change ?
Hi,
I hope to change my own Manual GearBox & Diff oil. Is 8" of lift adequate for access to the Fill/Drain plug ? My drive way is slightly off, Front & Rear axle may have an inch of height differences, Will that be a concern as well. I'm small build & BRZ is stock. Thanks |
| The Following User Says Thank You to redwine For This Useful Post: | humfrz (11-08-2020) |
#2 | |
I reckon the 1" height difference of 1" isn't going to make a significant difference. |
#3 | |
Señor Member
Drives: '17 BRZ PP
I myself have been wondering about this and even though the slope on mine is minimal, the idea makes me incredibly uncomfortable. I only lift front or back on my driveway. |
| The Following User Says Thank You to Plumbus For This Useful Post: | humfrz (11-08-2020) |
#4 | |
The Dictater
Drives: '13 Red Scion FRS
| The Following User Says Thank You to Spuds For This Useful Post: | humfrz (11-08-2020) |
#5 | |
I thought he was more concerned with having enough space under the car to do the work and whether or not the height difference would make a significant difference in the fluid levels. Back in the day, the jack stands (concrete blocks and pieces of 4"x4"), were less of a concern than the jacks we used. (ask ol @Tcoat how many times he had a car slip off one of those jacks) -
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (11-08-2020) |
#6 |
well of course use wheel chocks, silly -
#7 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (11-08-2020) |
#8 |
Drives: 2020 Subaru BRZ TS
Seriously, save the money and buy a QuickJack. Best money I spent on tools.
| The Following User Says Thank You to SUSPECT_BRZ For This Useful Post: | Wally86 (11-10-2020) |
#9 |
Thanks for all the inputs.
I'm thinking to custom make 4pcs of Ramp (8") from High Impact Foam. They are really light & i suppose they are easier to work with than wood. Of course will also have another safety backup. |
| gearbox and diff oils | danielmailrs | Engine, Exhaust, Transmission | 9 | 11-21-2018 08:50 PM |
| Diff Gear Change | Riftur | Engine, Exhaust, Transmission | 35 | 08-20-2016 04:14 PM |
| Gearbox Loose and "Slushy" Sound When Under 2200 RPMs | astrubinger | Issues | Warranty | Recalls / TSB | 9 | 07-08-2015 11:48 PM |
| DIY Oil Change: Brand of oil you use and method you use to jack/lift | PPX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 24 | 08-22-2014 12:09 PM |
| Clutch / Diff / Gearbox issue? | doggy | Issues | Warranty | Recalls / TSB | 5 | 10-03-2012 11:47 AM |
