Old 10-29-2020, 04:04 PM   #1
Sky4ce
Drives: Subaru BRZ
humming noise during hight speed right turns.
Hi everyone,
My car is 2013 Subaru BRZ, bought recently used. I am encountering unknown issue during high speed driving: humming noise only when turning right (even slight move of the steering wheel to the right is enough) at speeds over 110km/h- 70m/h. It can be felt as slight vibration of car body.
Since then I changed the tires for new one, new tie rod ends (both), new front stabilizer links (both), setup of geometry. No change to the noise.
Anyone of you had this issue in past? Any ideas?
I checked the forum but could not find anything similar to this issue.
Below link to video:
Sky4ce is offline   Reply With Quote
Old 10-29-2020, 05:45 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Front left wheel bearing/hub.
humfrz (10-30-2020)
Old 10-29-2020, 06:46 PM   #3
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Definitely a symptom of a wheel bearing failing on the left side.
Old 10-30-2020, 05:10 PM   #4
Sky4ce
Drives: Subaru BRZ
ok, than wheel bearing replacement is coming will update after its done.
Humming noise from head unit jordan7831 Electronics | Audio | NAV | Infotainment 5 12-05-2017 09:43 AM
Fan static/humming noise Zhangy Issues | Warranty | Recalls / TSB 8 08-26-2017 10:47 PM
Humming noise on left turns. kphan Issues | Warranty | Recalls / TSB 10 10-27-2016 12:49 PM
Humming noise while driving maylchi Issues | Warranty | Recalls / TSB 9 03-13-2015 02:29 AM
help!! weird humming noise?? sid94 Issues | Warranty | Recalls / TSB 3 05-17-2014 01:16 PM
