Old 10-29-2020, 12:23 PM   #1
paintdude258
paintdude258's Avatar
Do I need a new tune after replacing engine?
I spun a bearing and replaced my 2013 motor with a low mileage motor from a 2016 brz that was wrecked.
I was at 100k miles on the blown motor and the newer motor has around 30k miles.
The car is turbo'd.
Will I need to get a new tune once I get everything reinstalled? Will I need to change anything else such as the engine code for the tune?
Also, I am considering/planning switching from a crawford AOS to a dual VTA catch can set up. Will this affect the tune in any way?
Thanks for the help!
paintdude258 is offline   Reply With Quote
Old 10-29-2020, 01:02 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
No car is exactly the same. It's always a good idea to retune after a major change. While this SHOULD be 1:1, a custom tune is tailored for your car, (mods, exactly how much fuel it's pushing, exact compression numbers, AFR's, everything.) They CAN BE significantly impacted if the old motor was low on compression and the new one isn't, or the new engine is particularly healthy.
Keep an eye on your fuel trims and AFR's and if all looks consistent you should be okay. I would always recommend you have your tuner check logs at least once after a major component replacement like this if your numbers aren't lining up PERFECTLY to what they were before.
JazzleSAURUS is offline   Reply With Quote
The Following 3 Users Say Thank You to JazzleSAURUS For This Useful Post:
CSG Mike (12-10-2020), DarkPira7e (10-29-2020), paintdude258 (10-29-2020)
Old 10-29-2020, 01:24 PM   #3
paintdude258
This is exactly what my tuner said, so thank you greatly for the response.
I was under the assumption that I would need a whole new tune, so this is music to my ears. I will be sure and datalog once I get everything back up and running just to be sure.
The Following User Says Thank You to paintdude258 For This Useful Post:
Old 12-10-2020, 11:21 AM   #4
JazzleSAURUS
No prob, how's it running?
Check engine, can OFT tune help? slyder Software Tuning 15 01-23-2021 03:53 AM
Replacing front cross-member without taking engine out RapidEntropy Engine, Exhaust, Transmission 7 07-14-2020 05:45 AM
PSA: Replacing Engine Mounts can be a BITCH and much more! Sportsguy83 Engine, Exhaust, Transmission 51 02-19-2019 05:40 PM
Engine Tune Needed for Track Day? Faulkner Engine, Exhaust, Transmission 21 11-21-2018 07:08 PM
Engine / Tune Issues 1Botnet Engine, Exhaust, Transmission 4 09-05-2018 06:10 PM
