Old 10-21-2020, 06:05 AM   #1
Biggumzzz
Drives: Toyota 86 2014 GTS
Question Rear Popping noise when going up driveways on angle
So by the title, my 2014 86 makes a popping / rubbing sound in the rear on the passenger side (Australian) when I go over bumps or driveways on an angle only. Pretty much when there is twisting motion in the chassis. It’s something behind the plastic panels in the rear where the speakers sit. Around there. Any clues and anyone know about this? Cheers guys!!!
Biggumzzz is offline   Reply With Quote
Old 10-21-2020, 11:12 AM   #2
Vital
Drives: 2015 BRZ
Maybe this: https://www.tsbsearch.com/Subaru/12-140-12
Old 10-21-2020, 01:13 PM   #3
Biggumzzz
Originally Posted by Vital View Post
I’ve already separated the plates and taken rear shelf out and sprayed white lithium grease and closed the gap again. Still no luck
Old 10-21-2020, 01:17 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
Stop listening out for it, it'll soon go away. I'm now completely oblivious to creaks, clicks or other noises.. Just enjoy the drive.
Old 10-21-2020, 03:48 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@Biggumzzz
Are you lifting one of the rear wheels? Probably the "e-diff" kicking in.
If one of the rear wheel completely loses traction (e.g. going up driveway angled), the torsen diff is open. That means all the power will go to the wheel that is lifted, and you are stuck there. The TCS applies braking to the lifted wheel so that power can go to the gripping wheel and keep the car moving.
If that's not it, check your top hat nut or end links to make sure they are snug
EndlessAzure is offline   Reply With Quote
Old 10-21-2020, 10:36 PM   #6
Biggumzzz
Originally Posted by EndlessAzure View Post
@Biggumzzz
The sound is like it’s inside the car interior. Not an outside mechanical problem. Like two plastic panels rubbing together. Not sure
angle, bumps, popping, rear, sounds
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Noise - popping/clack :( Annoying Mikeez Issues | Warranty | Recalls / TSB 6 10-24-2014 01:28 PM
TRD Air Intake Popping Noise ButtonMasher Issues | Warranty | Recalls / TSB 2 03-27-2014 02:18 PM
