Old 09-25-2020, 09:21 PM   #1
Kitsube_
Kitsube_'s Avatar
Drives: White 2019 BRZ
“Brake malfunction”
Hello all, hope all is well.
A couple of days again I returned from the store and aired my car out to run inside, I spent about an hour inside or so until I went back to the car and got in, I immediately noticed my breaks where stiff and my brake lights would not turn on, I tried starting again and this time I was told by the gauge cluster I had a “brake malfunction” ABS light, power steering, and when I turned the car off, another message popped up and said “check access system with electric key”
I’ve look everywhere and can’t find the answer or the reason why it’s doing this, I’ve replaced fuses, swapped batteries with a friend, and as I type this Im restarting the ECU. I even replaced the battery in my key fob as well as the brake light switch and still no luck. Any help would be greatly appreciated. Thank you and have a great day
Kitsube_ is offline   Reply With Quote
Old 09-25-2020, 10:14 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
Was it throwing a CEL? You could try a code reader.
Jdmjunkie is offline   Reply With Quote
Old 09-25-2020, 11:19 PM   #3
Kitsube_
Kitsube_'s Avatar
It unfortunately won’t produce enough power for me to plug in my Code reader
Old 09-26-2020, 01:02 AM   #4
anticubus
Drives: 2017 Toyota 86
Sounds like the issue right there. Time to check your battery and alternator, your car should have enough juice to power an OBD2 reader. If they're good you've got some gremlins in your electricals.
anticubus is offline   Reply With Quote
Old 09-26-2020, 03:07 AM   #5
Hello Kitsube and welcome to our forum -
Sounds like you got a BIG electrical problem.
Is your car still under warranty?
When you left your car to "air out" for an hour, did you leave it running?
Did you check the two big fuses on the battery terminal?
If you have a volt meter, what does the battery read?
Did you clean the battery terminals?
I'd suggest you put your battery on a battery charger for a spell.
Come back.
anticubus (09-26-2020), ls1ac (09-26-2020)
Old 09-26-2020, 03:58 AM   #6
Kitsube_
Kitsube_'s Avatar
Ahhhh, it’s weird because I can hear the clicking in the engine bay, the dash, AC, clock light and other things still turn on in the car, just won’t let me start it
Old 09-26-2020, 04:00 AM   #7
Kitsube_
Kitsube_'s Avatar
Come back.
Car is still under warranty however I’ve done some aftermarket things to it and the last time I took it to the dealership, they made a big deal about it
After I aired out, I turned the car off
One of the fuses on the battery looks blown, could that be it?
The Following User Says Thank You to Kitsube_ For This Useful Post:
humfrz (09-26-2020)
Old 09-26-2020, 04:05 AM   #8
Yep, that could be it.
I suggest you replace it and see if the car rights itself -
Old 09-26-2020, 02:26 PM   #9
What do you mean when you say “aired out”?
Yep a blown battery fuse would be an issue. The bigger question is what blew the fuse?
What mods have you done? Anything recent?
Old 09-26-2020, 03:37 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Hey Kitsube, why are you chasing the fault, isn't the car still under a warranty? If it drives I would take it straight to the dealer and if it doesn't drive then get the dealer to pick it up..
Old 09-26-2020, 06:30 PM   #11
Kitsube_
Kitsube_'s Avatar
Car is still under warranty, however I’ve don’t a lot of aftermarket stuff in terms of engine modifications and cosmetics so I don’t want to trip, if I can fix it for cheaper then that’s what
Old 09-26-2020, 08:58 PM   #12
jflogerzi
jflogerzi's Avatar
Air out I am guessing air suspension. I would check your fuzes
2013 Series 10 FRS #553
Old 09-27-2020, 12:28 AM   #13
Kitsube_
Kitsube_'s Avatar
headers
Tune-E85
CAI
And that pretty much it beside the Airlift
And I haven’t done anything recent
Old 09-27-2020, 04:15 AM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
I had done some mods to my car during its life under the manufacturer's warranty period. I had no issues getting stuff sorted under the warranty. Mind you, there wasn't a lot of stuff to sort, battery died and valve recall. I even had the dealer install Group N engine mounts when they sorted the valves, they did it for zero labour cost.
Nice dealer...
Day Trip MPG malfunction Jrider Electronics | Audio | NAV | Infotainment 6 06-26-2016 01:14 AM
Day Trip MPG malfunction Jrider Issues | Warranty | Recalls / TSB 11 06-25-2016 06:00 PM
Auto-lights malfunction? gled21 BRZ First-Gen (2012+) — General Topics 10 11-11-2015 06:10 PM
BRZ temperature display malfunction percyng CANADA 7 10-24-2012 10:31 PM
First Malfunction? Ishii Motors Scion FR-S / Toyota 86 GT86 General Forum 6 06-09-2012 01:16 PM
