Old 09-16-2020, 07:36 PM   #15
Last time I had the trans out, I used a dremel to grind down the shelf left behind in the middle of the socket as the ball wore into it. Then I lapped the ball and socket a little to verify that where once was a shelf was now a tiny bit lower such that the only contact surface between the two was just outside that flat region on the ball. Used poor man's Prussian blue, a blue Sharpie. It works okay.
humfrz (09-16-2020), soundman98 (09-16-2020)
Old 09-16-2020, 09:27 PM   #16
Last time I had the trans out, I used a dremel to grind down the shelf in the middle of the socket left behind as the socket wore into the ball. Then I lapped the ball and socket a little to verify that where once was a shelf was now a tiny bit lower such that the only contact surface beteen the two was just outside that flat region on the ball.
Ball lapper!!!!!
humfrz (09-17-2020), sato (09-17-2020), Ultramaroon (09-16-2020)
Squeaky Clutch Noise, Help? Jfheisenberg Engine, Exhaust, Transmission 9 08-16-2018 12:51 PM
How I fixed my squeaky clutch jacjac3 Issues | Warranty | Recalls / TSB 40 09-27-2017 11:35 PM
Squeaky Clutch when depressed! oppiee Issues | Warranty | Recalls / TSB 29 09-01-2016 08:01 PM
squeaky clutch issue bhbnuckle Issues | Warranty | Recalls / TSB 3 06-27-2016 04:58 PM
Squeaky clutch V1B Engine, Exhaust, Transmission 24 06-16-2016 04:48 AM
