Old 09-08-2020, 08:59 PM   #1
Bluefire98
Drives: 2015 Scion FRS
Car not starting in the thick smoke in Oregon
Ok so, my car died on the freeway. I lost power steering first then pulled over, and now my car won't start at all. Checked the battery terminals and they look good. Checked for any loose connections and didn't find any. My dash lights up when turning the key and I can hear the fuel pump prime but it doesn't crank. Any ideas? Car has 69k on it. I've had a uel header and oft tune on it for about a year now. Car has never done anything like this before. Also a few miles before this happened, I hit a bump and it was liked my car turned off then back on quickly. Also I live in Oregon and there has been an insane amount of smoke today, so I wonder if that has anything to do with it. Checked the intake (stock) and it looked fine. I did a quick search and didn't find something quite matching my situation so figured I'd start a new thread. Thanks in adavance.
Bluefire98 is offline   Reply With Quote
Old 09-08-2020, 09:22 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
How are your ground straps looking?
Old 09-08-2020, 09:32 PM   #3
Bluefire98
Just fine. I'm at work right now but when I looked at the car I didn't see anything out of the ordinary.
Old 09-08-2020, 09:38 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Any codes? I am driving my car around in this shit, it is fine
Old 09-08-2020, 09:50 PM   #5
DarkPira7e
DarkPira7e's Avatar
You looked underneath at the ground straps?
All right, have you tried booking jumper cables or a jump pack to it? It's possible for it to have enough battery to illuminate the dash and not turn the starter.
If it's a standard car, have you tried having someone push you and then dropping the clutch to pop start it?
Also if manual, make sure there's nothing stopping the clutch pedal from depressing the switch, like a jammed up floor mat.
Old 09-08-2020, 10:55 PM   #6
Bluefire98
A jump didn't work. I'll pop start it to get it home at least. Maybe a fuse? And no codes. Actually my oft isn't reading anything.
Old 09-08-2020, 11:07 PM   #7
Is your ECU well grounded?
Are the big fuse things on top of the battery not blown?
Bluefire98 (09-10-2020)
Old 09-08-2020, 11:08 PM   #8
Bluefire98
Wait think I found the fuse, will report back if it's fixed
The Following User Says Thank You to Bluefire98 For This Useful Post:
p1l0t (09-09-2020)
Old 09-10-2020, 07:32 PM   #9
Bluefire98
Took subaru a day to get the fuse in but popped it in and she started right up. It was just the one on the positive battery terminal. Plastic piece with 2 fuses and 3 wires hooked up to it. Thanks for suggestions everyone (humfrz got it!)
Old 09-10-2020, 08:27 PM   #10
Glad you got it fixed -
Subsonic (09-10-2020)
Old 09-11-2020, 12:26 AM   #11
Decep
Drives: 2013 FR-S Series 10
Weird, any mods that could have caused the fuse to blow?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
New brake pads too thick UNCC_BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-06-2018 08:27 PM
FS: JPM Coachworks thick wrap Alcantara Steering Wheel Sccabrz192 Interior Parts (Incl. Lighting) 1 06-06-2017 07:58 AM
Centric Premium Rotors - too thick? smbstyle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-31-2014 02:01 AM
Silicone coupler or similar that is 4" I.D., and 1 inch Thick... (SOLVED) Sportsguy83 Engine, Exhaust, Transmission 11 06-19-2014 12:29 AM
