Old 07-20-2020, 07:55 AM   #1
mircea
Drives: scion fr-s
air inlet damper control sub assembly for Scion FRS 2016
Hi
I bought a scion frs produced in 2016 and now I find that when I select the air to blow to the window or front does not work. Just blow to the window. The reason is that the whole assembly with the motor that does this is missing (I think it's called air inlet damper control sub assembly) and I found the plug with the cables that is not connected anywhere.
Can anyone tell me the link where I can look for spare parts or can send me the spare parts catalog?
Thanks a lot!
mircea is offline   Reply With Quote
Old 07-20-2020, 08:07 AM   #2
Here are the repair manuals https://demos.starbase7.net/t3Portal/
Here are the part number and one source to order from https://parts.toyota.com/Scion_2016_...ditioning.html
humfrz (07-20-2020), JesseG (09-03-2020)
Old 09-02-2020, 09:44 AM   #3
mircea
Drives: scion fr-s
thank you!
The Following User Says Thank You to mircea For This Useful Post:
JesseG (09-03-2020)
WTB: Camshaft Timing Oil Control Valve Assembly Connector driftking96 Want-To-Buy Requests 8 05-18-2022 08:02 PM
FS: SILVER Traction Control Switch Assembly zeal86 Interior Parts (Incl. Lighting) 7 12-30-2018 12:02 AM
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 05:36 PM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 01:10 AM
is there a shorter endlink out there? mcs motion control damper toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-19-2014 08:28 PM
