Old 09-03-2019, 12:18 PM   #1
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Oil pan gasket
Is the oil pan glued on like everything else on this motor, or is there an actual gasket on there? I plan to pull the pan this weekend to check the pickup screen for rtv and want to have the correct gasket onhand when reassembling...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 09-03-2019, 12:34 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's just hearty sealant had to pry mine off with a pry bar gently.
venturaII (09-03-2019)
Old 09-03-2019, 08:04 PM   #3
venturaII
venturaII's Avatar
Gotcha. I'll use up my remaining Yamabond.
Old 09-05-2019, 02:46 PM   #4
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Car companies are steering clear of using gaskets when they can. Much cheaper to just use sealant and the failure rate is less.
MJones_RB is offline   Reply With Quote
Old 09-05-2019, 04:28 PM   #5
ermax
ermax's Avatar
On the pan it's probably fine to use Yamabond but to be safe you may want to just buy TB1217H. It's about $19 on Amazon.
https://www.amazon.com/Three-Bond-Vi...gateway&sr=8-1
And while you are at it maybe buy this tool ($25):
https://www.amazon.com/Engine-Transm...gateway&sr=8-1
This tool has a sharp edge with a good surface to hit with a hammer and once hammered through the seal you can pull on the handle to pry the pan off. It gives more leverage than a screwdriver and a lot easier to hammer than a putty knife. Mainly due to clearance. If I recall the service manual recommends an SST that is almost identical.
The Following 4 Users Say Thank You to ermax For This Useful Post:
gravitylover (09-06-2020), Icecreamtruk (09-05-2019), Joon525 (09-06-2019), venturaII (09-05-2019)
Old 09-05-2019, 05:12 PM   #6
venturaII
venturaII's Avatar
That's a slick little tool...I like it.
Old 09-02-2020, 08:33 AM   #7
ML
ML's Avatar
Drives: 13 White MT FR-S
found one :
https://www.ebay.com/itm/Engine-Oil-...-/203069917020
The Following User Says Thank You to ML For This Useful Post:
Joon525 (01-31-2021)
OEM Muffler Gasket JR007 Engine, Exhaust, Transmission 5 09-03-2024 09:48 PM
Chasing an exhaust leak -Donut gasket or gasket exhaust came with? xZAMx Engine, Exhaust, Transmission 7 08-28-2019 10:47 AM
SOLD: Brand New 2 Sets Of Gasket Ninja Tailight Gasket Kit With 3M Adhesive el-guapin Exterior Parts (Aero, Lighting, Etc.) 5 12-27-2018 03:54 AM
WTB: Midpipe gasket Admired Engine, Exhaust, Bolt-Ons 1 11-16-2013 12:46 AM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 08:22 AM
