Old 08-28-2020, 03:08 AM   #1
BayArea_FRS
Drives: 2014 Scion FRS
Need Help OFT ERROR CODE
Hey so I already had a tune installed for a while but was trying to change tunes. During installing the new tune it erased my ecu file like normal but then failed , So now I I have no ecu tune at all and can’t start my car. I’ve tried installing the same tune I was on and each time I do I get an error code 10010. I can’t even go back to the original file. I’ve been trying for the past 3 hours. And I’m in a parking garage where my car can get towed so I can’t leave my car.
This is the error
An error accused while writing the ECU. Check Cable connections, ignition switch positions, then try again later. OFTCODE: 10010
I’ve tried disconnecting the battery
Installing new tune files
Making sure all windows are up and doors closed
Checked cable connections
BayArea_FRS is offline   Reply With Quote
The Following User Says Thank You to BayArea_FRS For This Useful Post:
Lav (09-13-2022)
Old 08-28-2020, 08:03 AM   #2
steve99
Drives: FT86
This is the error
make sure barry volts above avout 12 v
also try writing the stock ie original tune file to car
Old 08-28-2020, 09:36 AM   #3
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
This is the error
The power doesn't come on at all? Unfortunately you might've bricked your ECU. In the meantime you can try and keep paying your parking another day so you can get help with it. You're battery might've died in the process. Try getting a new on and doing it again.
BlOody_BoOger is offline   Reply With Quote
Old 08-30-2020, 07:53 PM   #4
BayArea_FRS
The battery comes on
Old 08-30-2020, 08:38 PM   #5
Project_1796
Drives: Scion FRS 10 series
When you turn your car to the "on" position , 2 clicks on push to start/key position 2, do you hear the fuel pump energize? Also do you have the latest updates on the open flash tablet? You might have bricked your ecu if you powered off the car after the failed flash instead of trying to reflash the car again after failure.
Project_1796 is offline   Reply With Quote
Old 09-13-2022, 02:11 AM   #6
Lav
Drives: Frs
This is the error
DId you ever figure this out? Its kind of frustrating that after all the work Open Flash did on making these tunes + making them flashable by the end user, they went with the cheapest shittiest tablets possible. I'd have gladly paid an extra 100$ to not have to pray to god every time I switch off E85
Lav is offline   Reply With Quote
Old 09-13-2022, 03:35 AM   #7
oversteering
oversteering's Avatar
Drives: Toyota GT86 MY2017
I've got the same issue and i fixed it by program back the ECU using Tactrix.
oversteering is offline   Reply With Quote
Error Code B2779 Chris14a Issues | Warranty | Recalls / TSB 2 10-14-2018 04:58 PM
B1692 ERROR CODE NIKDENG Engine, Exhaust, Transmission 3 08-06-2016 12:37 AM
Help Error code C1241 acro Issues | Warranty | Recalls / TSB 3 04-19-2016 12:51 AM
Error code B14A1... wth is it? SirBrass Software Tuning 4 04-24-2014 06:37 PM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 02:09 PM
