Old 08-20-2020, 11:24 PM   #15
kthxbai
kthxbai's Avatar
Drives: '13 Whiteout FR-S M/T
Originally Posted by EndlessAzure View Post
If you want DRL, you will need to add a new wire:
  1. Either through a splice from the DRL resistor power ("traditional method" with high beam flap issue)
  2. Or a Splice from high beam power with a diode, to prevent the high beam from triggering at night due to the always-on module (this thread).
Thank you very much for the quick reply. Would you happen to have a photo of your actual set-up? I've never used a diode before because my wiring skills is just not at that level. Currently have the LED+ wire hooked to the DRL resistor + for DRL but it obviously does not work with the BeatSonic always-on module.
Sent from my Pixel 3 using Tapatalk
kthxbai is offline   Reply With Quote
Old 08-21-2020, 04:15 AM   #16
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Not sure the images will help all that much.
I don't remember if I modified the Beatsonic module pins, but I did splice the diode into the high beam power from there
The pin diagram should be accurate
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
kthxbai (08-21-2020)
Old 08-21-2020, 07:37 AM   #17
kthxbai
kthxbai's Avatar
I didn't even think about using the diodes on the module itself, just goes to show my lack of knowledge in the field of wiring. Thank you for taking the time to send the photos and pinout. You and the many other members are the reason why this forum is still thriving.
With the photos, I think it is making more sense. Will dive into this this weekend. If I have more questions, hope you don't mind me sending another message? Thanks again @EndlessAzure !
RS 1.0 Headlights for my Base FRS tonytduc DIY (Do-It-Yourself) Guides 3 04-18-2019 03:46 PM
Sparco seat base fitment issue? justinco Tracking / Autocross / HPDE / Drifting 5 05-18-2016 10:32 PM
Monogram Push Start Issue Ak1m0to Issues | Warranty | Recalls / TSB 20 02-12-2016 02:55 PM
FR-S base BeSpoke display issue! 6spd Electronics | Audio | NAV | Infotainment 6 08-08-2014 12:29 AM
WTB: FR-S Monogram Headlights willharp360 Exterior Parts (Aero, Lighting, Etc.) 0 04-21-2014 10:22 PM
