Old 08-09-2020, 10:46 AM   #1
radroach
Drives: car
Question about Port / DI changeover
I've wondered something regarding the Port / Direct Injection changeover point. I know that the car switches from port to direct injection some time after warmup and the car is stopped, idling for ~5 -10 seconds.
My question is, what happens if you don't stop and let it idle down / switch injection modes? What if I leave my house right now and get on the highway and drive two hours without stopping? Will it stay stuck in port injection mode?
Old 08-09-2020, 10:48 AM   #2
Gloonge
Drives: 2013 frs raven
It should switch the injectors as necessary. I don't believe that the port injectors are only used for startup.
Gloonge is offline   Reply With Quote
Old 08-09-2020, 03:26 PM   #3
Fred E
Drives: WRB BRZ
Once you start driving and pressing the gas pedal, the ECU changes over to 100% direct. The port injectors only inject at higher loads for supplemental fueling.
Fred E is offline   Reply With Quote
Old 08-09-2020, 06:33 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Incorrect.
This is the ratio map for Port Injection - 0% is DI only, 100% is PI only (table is slightly modified, the red boxes should also read around 35%)
That is for original cars, the facelift actually run PI more at higher loads, likely to do with better fuel mix.
@radroach it makes no difference when you set off. What you have read is about idle only.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-11-2020, 08:17 AM   #5
Fred E
Drives: WRB BRZ
Originally Posted by Kodename47 View Post
Incorrect.
I'm confused; doesn't that table confirm what I said? 0% port ratio at lower loads (less than .4) and a non-zero ratio at higher loads? My experience is limited to what I've observed on my own car, but it must have been tuned that way if that's different from stock; sorry for any confusion.
Old 08-11-2020, 12:28 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The verbiage you used was that once you start driving and adding load, the ECU switches to 100% direct. I think that's why he was confused
Old 08-11-2020, 04:03 PM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Correct, perhaps I was a little eager to jump the gun @Fred E. On a stock engine the only time it's 100% DI is at idle and at WOT between ~2300RPM and 4800RPM. The rest of the time it's a varying mixture.
You don't want to run too much DI only due to the cleaning of the valves and mixture formation.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-11-2020, 11:24 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
If you drive before the system is out of its warm up cycle it still uses a mix of port and direct except at idle.
1974 TA22 Celica
2013 86 GT
Searching For a replacement USB port for the factory port for aftermarket radio Kutanks Electronics | Audio | NAV | Infotainment 20 08-21-2021 08:12 PM
Complete Power Folding Mirror Changeover ChrisJ Exterior Parts (Aero, Lighting, Etc.) 4 05-09-2020 09:09 AM
Amsoil Trans/Diff Changeover Vukodlac Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-11-2016 09:36 AM
Testing Waters - Ful LED changeover $105($109 With Switchbacks for FRS) eljefe Interior Parts (Incl. Lighting) 11 08-09-2013 02:23 AM
