Old 08-08-2020, 02:07 AM   #1
teqnick
Drives: N/A
Throttle cut , now No Start?
Hey all,
Just last week, was cruising at about 60mph, nothing out of the ordinary, when I lose throttle response, almost as if I had a faulty MAF. Luckily, I was able to pull over, but since then, have been unable to get the car to start. No store codes, swapped out MAF. Car has been driving fine up to this point. Any ideas?
Plan on getting it towed to my local 86 shop, but figured I would check here before that.
Car is a 2013 BRZ, Stage 2+ OFT on e85, 80k miles.
Thanks!
teqnick is offline   Reply With Quote
The Following User Says Thank You to teqnick For This Useful Post:
humfrz (08-09-2020)
Old 08-08-2020, 02:28 AM   #2
padillaricardo48
padillaricardo48's Avatar
Originally Posted by teqnick View Post
Hey all,
Thanks!
First they will tell you to tone it back to stock and plus early models 2013 have many issues with the engine, might wanna swap it to a 2016 and up engine
Sent from my SM-N975U1 using Tapatalk
padillaricardo48 is offline   Reply With Quote
Old 08-08-2020, 08:32 AM   #3
KDad2
KDad2's Avatar
Drives: 2013 Raven
Hey all,
Thanks!
I had the same thing with my 2013 FRS a few years back. No codes or anything. It did start back up after a couple minutes. Only happened that one time.
KDad2 is offline   Reply With Quote
Old 08-08-2020, 04:38 PM   #4
p1l0t
p1l0t's Avatar
Does the battery have voltage? If not your alternator might be shot. If it does I find it odd that nothing happens when you press the button. Or maybe something does? And you should explain what lights/sounds you get..
Old 08-09-2020, 12:59 AM   #5
Hey all,
Thanks!
When you say "it won't start", do you mean it won't turn over or it won't fire?
DarkPira7e (08-09-2020)
Old 08-09-2020, 11:32 AM   #6
teqnick
Drives: N/A
Lights, and all electric work. The fuel pump is priming, but car just won't fire.
Thanks!
Old 08-09-2020, 12:30 PM   #7
ls1ac
ls1ac's Avatar
Still did not answer the question, will the engine turn over quickly? what kind of a noise will it make while trying to start? have you tried to jump the battery? (not booster cables but real jumpers)
Old 08-09-2020, 12:45 PM   #8
teqnick
Drives: N/A
Sorry, answered hurriedly this morning.
Turns over quickly, as normal - just not firing. Have tried jumping the battery as well, yes.
humfrz (08-09-2020)
Old 08-09-2020, 04:34 PM   #9
norcalpb
norcalpb's Avatar
I had a similar issue that ended up being the fuel pressure regulator
Old 08-09-2020, 07:21 PM   #10
Welp, that leaves fuel, compression, air or spark - there I got ya started -
p1l0t (08-10-2020), soundman98 (08-13-2020)
Old 08-10-2020, 08:31 AM   #11
steve99
Drives: FT86
Unplug MAF mass air flow sensor at air box , will car start with maf unplugged ?
The Following 2 Users Say Thank You to steve99 For This Useful Post:
humfrz (08-10-2020), p1l0t (08-12-2020)
Old 08-13-2020, 04:18 AM   #12
Immaculate Fury
Drives: 2014 Red BRZ Premium
I had this exact thing happen to me when I owned a 2004 Lancer. All the same symptoms. All power worked, car cranks indefinitely, lost throttle response while driving on the highway. Car was running and continued to "run" while it slowly coasted to a stop and died. Could throttle all I wanted and no engine response
It ended up being the crankshaft position sensor
Immaculate Fury is offline   Reply With Quote
HELP! Cold start rattling sound when press throttle. kishi23 Engine, Exhaust, Transmission 20 01-22-2026 02:16 AM
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
grams throttle body install, won't start jdair28 Engine, Exhaust, Transmission 34 06-26-2019 12:31 PM
Popping noise from engine bay during start up, free rev, light roll on throttle heeltoe86 Tracking / Autocross / HPDE / Drifting 44 12-01-2014 10:28 PM
