Drives: gt86
Do I need to change bolt and seal for Perrin crank pulley install
Bought a Perrin pulley. I found this install video where he says you need to replace the seal and bolt during install. He also torqued it like crazy with a breaker bar to the point that the bolt is wobbly when the car is on.
Wondering is this the right way to install it? Or should I just follow the instructions that came in the box? Do I need to replace bolt and seal? Thanks |
#2 |
Drives: Crapcan
Technically, it is a stretch bolt and should be replaced.
That being said, I have used the same bolt 3 times now. If your car is high mileage, I would probably go ahead and replace the seal while you are there. If it looks good and is not leaking don't worry about it, just be mind full of the seal when installing. And torque it properly.
#3 |
change pulley for a stock one
#4 |
Drives: gt86
Thanks. I looked through the manual for that section.
The manual mentions the -timing belt housing seal -spacer o ring -bolt. It says to put in a new spacer o ring. But it didn’t say if the seal and bolt need to be replaced or can be reused. |
#5 |
Rust bucket enthusiast
It's worth the pocket change to just replace the bolt. No sense in taking a risk when it's 100% avoidable
#6 |
Drives: Crapcan
That is what I did. The Perrin one is now a paperweight on my desk.
#7 |
Drives: '15 BRZ RA
You don't need a new bolt, but it is a good idea to install a new one if you have a highly mileage car.
#8 |
Drives: gt86
#9 |
Drives: Crapcan
Switched to stock to see if I could tell a difference. Couldn't so left it on.
#10 | |
![]() The main screw is perfectly fine. Mileage has absolutely nothing to do with it. There is an important section in all good documentation that explains how to use it. A common convention is that black dot. In the exploded parts diagrams, all items can be considered reusable unless expressly indicated by that symbol.
#11 | |
Drives: Crapcan
#12 | |
#13 |
Drives: '15 BRZ RA
Yes the manual says it is reusable. It doesn't say anything about high mileage. I just prefer to change bolts in such kind of components for the peace of mind.
#14 |
Drives: Scion FR-S 10 Series
Arp also makes a replacement crank bolt.
| [GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt | reeves | Engine, Exhaust, Bolt-Ons | 0 | 08-22-2018 07:01 PM |
| DIY - Lightweight crank pulley install (Perrin) | justinco | DIY (Do-It-Yourself) Guides | 11 | 05-22-2017 04:35 PM |
| Perrin Crank Pulley Install (time lapse vid) | ninjasaurusrex | DIY (Do-It-Yourself) Guides | 0 | 03-12-2014 01:42 AM |
| Crank pulley bolt | tech4pdx | Engine, Exhaust, Transmission | 5 | 03-04-2013 08:18 PM |
| Camshaft Bolt Coming Loose After Perrin Pulley Install | WhiteBRZ | Engine, Exhaust, Transmission | 25 | 09-20-2012 08:07 AM |
