Old 07-20-2020, 01:21 AM   #1
colin88
Drives: 2013 Toyota 86
Aftermarket fuel systems / filtration
Looking for an aftermarket solution for the fuel filter.
Currently run e85 and have had the fuel filter degrade and need replacing at 35k.
The radium hangers are great but come at a cost, so I was wondering if anyone has a diy/different solution to aftermarket filtration and supply from tank, that may or may not also include a surge tank.
Sent from my SM-N975F using Tapatalk
colin88 is offline   Reply With Quote
Old 07-21-2020, 01:50 AM   #2
Project_1796
Drives: Scion FRS 10 series
You can use the dw fuel socks too
https://ftspeed.com/part/9-1010-deat...7#.XxZzi1NlDqs
Project_1796 is offline   Reply With Quote
Old 07-21-2020, 05:15 AM   #3
colin88
Originally Posted by Project_1796 View Post
I have a dw pump and sock in factory hanger. The after pump filter is the one im talking about. Sorry I should have been a bit more specific.
Old 07-21-2020, 11:02 AM   #4
Project_1796
The in tank filter is the only filter that we have. Unless you're running external fuel filter? Did your fuel sock disintegrate or something?
Old 07-21-2020, 10:14 PM   #5
colin88
The sock is a pre-filter. The in tank filter is part of the hanger .
The hanger is the one im trying to make external or bypass. See image
Old 07-22-2020, 03:33 AM   #6
Project_1796
I forgot about the non servicable one. Either oem or go with radium
Old 07-29-2020, 11:45 AM   #7
hifiguy99
Drives: 19' Toyota 86 TRD
Is this a common issue? How'd you find out about it?
I have found only one other instance, mentioned here:
https://www.ft86club.com/forums/showthread.php?t=64621
hifiguy99 is offline   Reply With Quote
Old 08-20-2020, 05:29 AM   #8
nkobns
Drives: Sideways
I have the same problem.
Car has 30k, around 20k on e85, and here is my fuel filter :
In France they don’t sell the filter only. I’d have to go with the complete fuel pump at $800...
Is there any aftermarket fuel filter that can fit the stock system ? (maybe the DW one ?)
nkobns is offline   Reply With Quote
Old 08-20-2020, 08:34 PM   #9
Grady
Grady's Avatar
These fuel filters work great!!!!
https://www.superwii.com/FOR-NAPA-24...4aAtVzEALw_wcB
Old 08-21-2020, 06:08 PM   #10
nkobns
Drives: Sideways
Originally Posted by Grady View Post
No clue of what this is ! I’ll take some time to educate myself
Thank you !
Approach to Aftermarket Exhaust Systems Seiryuu Engine, Exhaust, Transmission 33 06-02-2020 01:51 PM
Can aftermarket seats be installed while keeping all factory safety systems? edwardl Cosmetic Modification (Interior/Exterior/Lighting) 4 03-15-2020 03:13 PM
Is there a way to tell if you have aftermarket fuel injectors? haute Engine, Exhaust, Transmission 1 07-23-2019 03:29 PM
Aftermarket Fuel pressure gauge FutureFT86 Engine, Exhaust, Transmission 2 03-10-2016 11:22 PM
Do any aftermarket radio/nav systems offer gauges ? brillo Electronics | Audio | NAV | Infotainment 9 12-22-2012 03:03 AM
