Old 04-29-2014, 08:44 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
E85/ fuel system components update
Local 86 club owner asked about the in tank fuel filter and it again piqued my interest on the subject. As some of you may know, there was one instance of the fuel filter that is embedded inside the white pump casing disintegrating, and although never proven, it was believed E85 broke it down. (More info) http://www.ft86club.com/forums/showthread.php?t=37814
(PLEASE, THIS IT NOT TO DISCUSS E85 PROS/CONS, THIS IT FOR E85 USERS TO UPDATE IF THEY HAVE HAD ANY ISSUES WITH E85 DAMAGING ANY FUEL SYSTEM COMPONENT
So my question is to anyone and everyone using E85:
How long have you been using E85?
How frequent (all the time, run a 93 tank every few months, rarely)?
Have you had any issues directly related to it (filter disintegrating, rubber hoses cracking, etc)?
ME:
I've been using E85 since August 2013
Basically all the time except three tanks of 93; I now plan on running a tank of 93 from time to time with flex fuel.
Zero issues and that includes a period of three months the car sat without moving with e85 in the tank while turbo kit was designed. I opened the fuel tank because I later upgraded Fuel Pump, and there were no signs of filter wear or issues with any fuel system component.
Interesting information
Originally Posted by arghx7 View Post
How often do you put in E10? Every other tank? Once a month? One time since you initially switched to E85? Or have you literally run only E85 that entire time?
The reason why I ask is because Saab did some pioneering work on turbo [PFI] E85 applications back in the late 2000s. One of the things they found was that running E85 leaves deposits on the injectors, but occasionally switching to gasoline cleans them up very quickly.
Funny you mention that. If you read the Saab paper, they talk about how the deposits were not actually caused by the ethanol portion of E85. They were caused by additives in the gasoline portion. It's weird. Because of the way the fuel supply chain works they could never mix a blend of E85 that didn't have this propensity to cause buildup.
See attached paper, starting on page 29.
Old 04-29-2014, 08:47 AM   #2
CBR600RR
Drives: Raven Black
I ran E85 all last summer (start of May through to end of September) with one tank of 91 octane in between.
Zero issues (crickets do chirp though; I find they do with all fuel except Shell 91))
Old 04-29-2014, 08:59 AM   #3
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Been running Flexfuel since July of 2013. Zero issues. Mixed grades from E88 down to E10.
post_break is offline   Reply With Quote
Old 04-29-2014, 11:30 AM   #4
Sargy
Long Distance Driver
Sargy's Avatar
Been running E85 Since Dec, 2013. almost 10K miles
All the time
No issues to report. Love the smell
Sargy is offline   Reply With Quote
Old 04-29-2014, 11:38 AM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
E85 tuned since August 2013 with a few tanks of 93 over the winter, almost exclusively E85 since installing a Flex Fuel kit in early March 2014.
Zero issues other than being unable to find actual ethanol content over 75% around Atlanta.
I have been using Lucas Ethanol Fuel Conditioner with stabilizers occasionally as well.
http://www.lucasoil.com/products/dis...id=335&catid=8
Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers was developed to specifically address issues associated with using ethanol based fuels. This applies to E-10, E-15, E-85, pure ethanol and any mixtures in between including gasoline. Our Product is completely soluble in all ethanol fuels and will not harm filters. Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers contains effective additives to prevent rust and corrosion associated with the use of ethanol fuels.
Safeguard™ Key Benefits:
• Cleans injectors, valve seats, combustion chambers and other critical fuel components
• Stabilizes fuel and prevents varnish & gum formation in ethanol and gasoline
• Combats deposits and protects your engine oil lubricants from the harmful effects of alcohol combustion
Safeguard™ treats up to 80 gallons(302.8) of ethanol fuel. One ounce treats five gallons of ethanol fuel. Our new 5.25 oz bottle treats up to 25 gallons (94.6 liters) of ethanol fuel. Recommended for use in automobile and marine applications.
Old 04-29-2014, 11:57 AM   #6
mkivsoopra
Been running e85 since 500 miles on the odo, and I'm at 17,000+ now, with 3 tanks of 91 mixed in there somewhere. I pulled the pump a few days ago and although I didn't rip open the inside filter, nothing seemed to be out of the ordinary.
mkivsoopra is offline   Reply With Quote
Old 04-29-2014, 02:37 PM   #7
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I currently have over 44,000 miles with more than half of them being E85, and over 5000 of those being FI miles. I have had no issues, and the stock in tank pump looked fine when i upgraded it.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 04-30-2014, 07:19 AM   #8
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
been using e85 for about 10,000 miles on and off. No issues besides cold starts but that issue has been fixed for a while. Now that i plan on using e85 exclusively and also have flex fuel this is my plan.
Change oil every 2000-2500
With every oil change i plan on using the lucas ethanol fuel treatment
half a tank of gas every 1000 miles or so.
brichard0625 is offline   Reply With Quote
Old 04-30-2014, 07:50 AM   #9
86viper
Drives: 2013 Toyota 86 GTS
Been running e85 alone for 8400km, mixture of highway and smashing it.
It doesn't get cold here really so its been running it year round.
For the last 1000km i have been running the lucas ethanol treatment just to be sure.
Zero issues of any kind so far...apart from smiling too much!
86viper is offline   Reply With Quote
Old 04-30-2014, 08:33 AM   #10
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
I've been using strictly e85 since February of last year, around 18000 miles. Car gets used daily and driven hard. No issues, besides for cold starts in below freezing temperatures, and scrappy gas mileage.
Oh, and I'm still using the fa20club tune from Toni
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 07-03-2014, 05:04 AM   #11
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Would like to revive this thread. Been on e85 for a few weeks now, like 4 tanks or so. So not a whole lot, but everything is purring right along!! LOVE IT! MPG has suffered some, but not sure if it's from my lead foot or not...
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-04-2014, 04:23 PM   #12
Trettiosjuan
Drives: GT86
Does running E85 affect the chirping fuel pump in any way?
Trettiosjuan is offline   Reply With Quote
Old 07-04-2014, 04:53 PM   #13
post_break
post_break's Avatar
Usually makes it go away entirely.
Old 07-04-2014, 05:08 PM   #14
Trettiosjuan
Drives: GT86
That... sounds very good
Dynosty 1000 Fuel System Dustin@Dynosty Forced Induction 48 10-08-2018 05:27 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
fuel return system? lbroskee Engine, Exhaust, Transmission 4 03-04-2014 06:56 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
