Old 07-31-2019, 05:41 PM   #1
edwardl
Drives: 2018 BRZ
Can aftermarket seats be installed while keeping all factory safety systems?
Or will not having factory seats prevent airbags and other safety systems from working? I see a lot of things about airbag light bypass resistors and other stuff which has me thinking the answer is no.
edwardl is offline   Reply With Quote
Old 07-31-2019, 05:44 PM   #2
There are airbags in the stock seats so no not all systems. There are probably ways to get the sensors in aftermarket for the rest of the bags though.
Old 07-31-2019, 06:45 PM   #3
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
All of your other airbags will still work after installing aftermarket seats. You will need a resistor with a resistance of 3.3 ohms for each front seat that you replace.
-Sam
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
Tcoat (07-31-2019)
Old 07-31-2019, 07:12 PM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
-Sam
Not only airbag resistors, but also need to somehow get passenger sensor out and put it in or under the aftermarket seat... if you're installing both driver and passenger seats.
eastendraceshop (07-31-2019)
Old 03-15-2020, 02:13 PM   #5
18BrzBlue
Drives: 2018 Blue Brz
-Sam
Does the it matter if it 1w or 0.5w resistor. My amazon only sells these one I can find. Should they work for 2018 BRZ. I just replaced driver seat with a sparco.
https://www.amazon.ca/Projects-100EP...4295968&sr=8-7
18BrzBlue is offline   Reply With Quote
OEM heated seats in aftermarket seats Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 6 06-09-2024 12:31 PM
Lowering Stock Seats/Aftermarket Seats. Headroom Needed! RobGT86 Cosmetic Modification (Interior/Exterior/Lighting) 17 01-17-2019 05:53 PM
Keeping factory cats with header? robtan Engine, Exhaust, Transmission 7 12-27-2013 03:40 PM
VORTECH FACTORY COMPLETE SUPERCHARGER SYSTEMS! EVERYTHING YOU NEED! @Pure Automotive Pure Automotive Forced Induction 44 11-26-2013 08:25 AM
Do any aftermarket radio/nav systems offer gauges ? brillo Electronics | Audio | NAV | Infotainment 9 12-22-2012 02:03 AM
