Old 07-16-2020, 12:42 PM   #15
sato
sato's Avatar
Drives: Dodge Patitas
If I remember correctly, a friend's GC8 Impreza had the exact same issue.
sato is offline   Reply With Quote
Old 07-16-2020, 02:57 PM   #16
jeffs42885
Drives:
What was the fix?
jeffs42885 is offline   Reply With Quote
Old 07-16-2020, 03:46 PM   #17
sato
sato's Avatar
Originally Posted by jeffs42885 View Post
What was the fix?
Sorry if I didn't clarify much. Since he wasn't exactly rubbing, he "corrected" the misaligned look with different size spacers. He might have smaller wheels, but can't remember.
I just thought that it was a weird item, considering had any type of mishap with his vehicle.
Old 07-16-2020, 04:46 PM   #18
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I know the stance guys with mkiv VW's pretty frequently have a miss match from one side to the other in the rear (solid rear beam construction). 5-8mm spacers aren't uncommon to alleviate the issue.
CrowsFeast is offline   Reply With Quote
Old 07-16-2020, 07:36 PM   #19
jeffs42885
Drives:
I’m a complete newbie when it comes to this suspension stuff. But this is also concerning me. Notice how far back the passenger side wheel is compared to the drivers side
Old 07-20-2020, 04:50 PM   #20
Chamaco
Drives: Silver FR-S
something's not right there. Like another member suggested; take apart the sub frame to see if it shifted for some reason.
Chamaco is offline   Reply With Quote
Old 07-20-2020, 05:25 PM   #21
Tokay444
Post the alignment readout.
Why leave us all in the dark?
The Following User Says Thank You to Tokay444 For This Useful Post:
BigTuna (07-27-2020)
Old 07-25-2020, 05:34 AM   #22
Immaculate Fury
Drives: 2014 Red BRZ Premium
So... This is reminiscent of the issue I used to have on my 2004 ralliart lancer. One thing that would happen to the car is the bushings in the rear lower control arms would wear out and the mounting holes would be 'pulled' eccentrically outwards in the mount. This made the control arm 'longer' than it should be and resulted in exactly what OP sees. In my lancer it made the rear of the car squat down, bottoms of the tires would stick out slightly farther, and on larger rims and rubber they would run in the rear.
Looking at the pictures of the rear suspension setup it seems arranged in a lot the same way as that car. Try taking out the lower control arm on the offending side and see if the bushings are still okay. Might be all it is. But I could be wrong
Immaculate Fury is offline   Reply With Quote
Strange Rear Suspension Issue dvniemela Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-28-2018 10:35 PM
Help with suspension issue arkanist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-06-2018 06:59 PM
Suspension issue? Dacfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 12-08-2017 10:25 PM
Need Help with Suspension Issue Silverfox Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-04-2017 01:44 PM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
