Old 07-03-2020, 10:36 AM   #15
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by nico_rsx View Post
Pedal dance doesn't turn ABS off.
You need to remove the fuse to turn ABS off (which also mess with electronic brake bias I think)
i guess that explains why ive never locked my brakes up when long pressing before.
Old 07-04-2020, 06:58 AM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by M0nk3y View Post
I don't see in what way, if any, this is a good idea.
Intentionally removing ABS is asking for flat spotted tires, an off, something. Find somewhere else to remove an equivalent of -42 lbs.
I know while I don't intend to hit ABS, it happens, and it saves from a lockup. It's honestly such a bad idea...of all places to save -42 lbs this is the last place, IMO.
Right, because no one drove cars before ABS came along.
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
Icecreamtruk (07-13-2020), soundman98 (07-04-2020), Tokay444 (07-04-2020)
Old 07-04-2020, 11:03 AM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
i love how so many people honestly believe that ABS helps a car stop.
it DOES NOT help you stop.
it MAINTAINS CONTROL while stopping. it does this by sacrificing stopping distance for control while stopping.
it's for grandma's that have no concept of pedal modulation, that just mash the brake harder when things go wrong, instead of re-evaluating the situation and manually releasing the brake a little.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Captain Snooze (07-05-2020), Icecreamtruk (07-13-2020), Jdmjunkie (07-04-2020), Tokay444 (07-04-2020)
Old 07-04-2020, 05:00 PM   #18
racingfool
racingfool's Avatar
Drives: Miata
Threshold braking used to be one of the first things taught in a racing school.
With abs and traction control, the throttle and brakes are used like an on/off switch.
racingfool is offline   Reply With Quote
Old 07-04-2020, 10:50 PM   #19
soundman98
soundman98's Avatar
i'm of the opinion that threshold braking can be more precise than trying to allow the car to work it out, as the wheels need to first slip for the car to know to work anything out.
Old 07-05-2020, 01:48 AM   #20
nico_rsx
Drives: BRZ 2017 Pure Red, MT
You can do threshold braking without deactivating abs. If abs is kicking in, that generally means you failed your threshold braking and the wheels were starting to lock-up.
nico_rsx is offline   Reply With Quote
The Following 5 Users Say Thank You to nico_rsx For This Useful Post:
churchx (07-05-2020), GrandSport (06-12-2023), rice_classic (07-05-2020), soundman98 (07-05-2020), strat61caster (07-13-2020)
Old 07-07-2020, 02:28 PM   #21
racingfool
racingfool's Avatar
Drives: Miata
I could hear the inside front starting to complain about losing traction.
I was already trailing off the brakes and keeping the wheel rolling, abs kicked in anyway.
Old 07-09-2020, 02:36 AM   #22
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
The ABS you find on a regular street car is not meant for racing.
I'm used to racing a car without ABS, I'm hoping on my new BRZ the ABS doesn't give me any problems.
Breezio is offline   Reply With Quote
Old 07-13-2020, 08:37 AM   #23
steverife
Drives: 2016 Scion FRS
I've always been baffled by the anti-ABS crowd.
You should very rarely be getting into ABS and it may save your butt. Personally, I can push harder and more confidently without having to worry about lockup. You can get into ABS very slightly without ruining your run or your lap and that necessarily isn't the case with lockup.
steverife is offline   Reply With Quote
Old 07-13-2020, 11:29 AM   #24
Racecomp Engineering
If you can stop faster with the ABS fuse pulled in a BRZ, I will paypal you 5 dollars.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
GrandSport (06-12-2023), nico_rsx (07-14-2020), Pat (07-13-2020), Turbo (07-28-2020)
Old 07-13-2020, 02:19 PM   #25
CSG Mike
CSG Mike's Avatar
- Andrew
I can... but not repeatably.
Racecomp Engineering (07-13-2020)
Old 07-13-2020, 02:39 PM   #26
Icecreamtruk
Drives: Track preped NA FRS
If there's a wall in the way, I can stop faster too!
Im going to end up doing an ABS delete at some point, proper stuff tho, removing the whole unit reconnect the lines and add a proportioning valve to the rear line coming out of the MC to adjust bias.
But for OP's discussion, I believe the problem is that brake bias switches to the front quite a bit, its a pain to work around but not impossible. You might make something work with different pads front and rear but it might be easier to just add 42lbs of ballast.
Icecreamtruk is offline   Reply With Quote
Old 07-13-2020, 03:58 PM   #27
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
it's for 99.99% of drivers with no concept of pedal modulation, that just mash the brake harder when things go wrong, instead of re-evaluating the situation and manually releasing the brake a little.
ftfy
And yes, that includes weekend warriors.
imho the brake electronic brake biasing that allow the driver to actually use the brake mid-corner with the wheels unevenly loaded are awesome, I'm not in a hurry to get rid of it.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
CSG Mike (07-13-2020), nico_rsx (07-14-2020), Racecomp Engineering (07-13-2020)
Old 07-13-2020, 04:05 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
ftfy
I hadn't tracked my car since last September and it saved me a bunch Saturday. My foot work was quite clumsy.
Dashboard fuse box - mini fuse removal airrick Electronics | Audio | NAV | Infotainment 0 10-25-2019 06:05 PM
Removed createluck Wheels and Tires 6 02-02-2016 12:37 PM
REMOVED Chimera Audio/Visual, Electronics, Infotainment, NAV 1 06-28-2014 11:48 AM
removed Fast_Freddy DIY (Do-It-Yourself) Guides 11 11-02-2013 07:46 PM
