| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2022' GR86 Premium 6MT
Valve Cover Gaskets
Has anyone here had their valve covers done? Been trying to find threads but all i can find is timing cover post.
Curious if RTV is used in the process of replacing the gaskets. Getting my tube seals redone in a week or so and I'm nervous.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#2 |
Drives: Crapcan
You put some in a few spots on the cover.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | e1_griego (07-06-2020) |
#3 |
Drives: Many
Just did them a few weeks ago, followed that diagram^
#4 |
Drives: '13 Subaru BRZ Crystal Black Silica
Yeah follow the tech manual. Consider getting a gasket set too, to replace the spark plugs gaskets. I did mine like last month.
IG: setgo.moto
| The Following User Says Thank You to Setgo For This Useful Post: | VoltsFRS2013 (07-07-2020) |
#5 |
I have the tube seals next to me i got from my job, gonna head to toyota for the VC Gaskets =)
#6 |
Drives: FRS
I think my valve covers are also leaking. Is it possible to remove said covers without having to removing the front timing cover? Can this also be done without pulling out / removing the whole engine from the engine bay? Also, does one have to drain the oil before removing the valve covers?
I need also to replace my spark plug tube seals and would be doing it at the same time as this. |
#7 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | knucklehead (09-24-2020) |
#8 |
Drives: '13 BRZ Ice Silver Metallic
What’s the valve cover torque spec?
#9 |
Drives: Crapcan
57in·lbf
Tighten inside out in a crossing pattern.
#10 |
#11 | |
Drives: Crapcan
If you look in @Ultramaroon's sig he has the manuals linked. Just don't beat him at Dejarik or he will rip your arms off.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | bcj (12-21-2021), Capt Spaulding (12-21-2021) |
#12 |
Here’s the factory seal on mine. Seems excessive, but effective. It was the plug tube that failed on me. Looks like even touched the cam, I put a smaller bead.
| Rocker put a hole in valve cover | leets4uc3 | Engine, Exhaust, Transmission | 67 | 07-27-2018 03:14 PM |
| Other Oil leaks - Oil Pan gasket? - NOT Cam plate, valve cover, or Cam cover | exE36M3 | Issues | Warranty | Recalls / TSB | 17 | 11-08-2017 11:15 AM |
| Hole in valve cover | burdickjp | Issues | Warranty | Recalls / TSB | 25 | 11-29-2016 10:37 PM |
| Oil Leak from either Timing Cover or Valve Cover | BRZY | Issues | Warranty | Recalls / TSB | 5 | 04-06-2015 09:31 AM |
| Name that valve cover!!!! FA20???? | ESBjiujitsu | Engine, Exhaust, Transmission | 3 | 06-05-2012 10:42 PM |
