| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#43 | |
Drives: MY14 86 GTS Manual Velocity Orange
MTEC shift Springs MTEC Clutch Spring Adjusted clutch travel Whiteline Positive Shift Kit Whiteline Differential mount in cradle insert bushings Penrite GL4 Transmission Oil Penrite ShiftEZE It is all snickety snick once warmed up. My first to second shift still binds a bit when it is cold but it is way better than before. Takes a lot less time to settle down too. |
#44 | |
Drives: 2017 Toyota 86
I can't imagine it getting better, I love hearing first gear go whirRRRRrrrrr and I've never had this clunky, notchy stuff everyone complains about. Makes me want a dog box for the street, but I do occasionally have to let other people drive it
#45 |
Drives: _
Just a guess, but... the shifter rod linkage joints & bushings could have been worn too much?
A firm, intentional shift should engage the gears without issues. Sometimes the synchros take a little wearing in, but they are usually pretty darn good when it comes to making sure that gears are smoothly engaged. The V-shaped teeth sometimes could have little dulling/pitting on the tip that could cause some hesitation. Maybe regular oil changes might keep the surfaces clean for friction-free sliding |
| First and Second gears are clunky... | mcrane | Engine, Exhaust, Transmission | 0 | 12-05-2015 12:39 PM |
| Shifter feels clunky when going into 5th | Jfheisenberg | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 04-04-2015 08:41 PM |
| Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 01:48 AM |
| Rear rattle/clunky noise | Hawk77FT | Issues | Warranty | Recalls / TSB | 8 | 08-18-2013 07:59 PM |
