Old 06-28-2020, 01:14 PM   #1
Daily86
Daily86's Avatar
Drives: 2017 Toyota 86
OFT V4 Tunes idle issue
'17 86 AT. OFT V4 stg1 & stg2+E85 tunes. When started and the engine is cold, idle is steady. When shifted to drive or reverse idle jump up a few hundred RPM. I had V3 tunes before and they didn't behave this way. After engine is warm doesn't do this either. Anything I can change? Besides getting a manual.
Daily86 is offline   Reply With Quote
Old 06-28-2020, 02:48 PM   #2
tomm.brz
Drives: brz 2017 hksv2
probably the cold start that got tamed in v4 tunes, maf compensations are different
Old 06-29-2020, 05:10 AM   #3
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If it runs poorly, it's because the MY17 files for black manifold 6AT just have the tables for 6MT red manifold.
The Following User Says Thank You to Wayno For This Useful Post:
tomm.brz (06-29-2020)
Old 06-29-2020, 08:07 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
https://www.ft86club.com/forums/showthread.php?t=139501
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-29-2020, 08:27 AM   #5
Daily86
Daily86's Avatar
Thanks. I will check this out.
Old 06-29-2020, 08:18 PM   #6
steve99
Drives: FT86
If its oft V4 tune maf correction after start tables in gear and in neutral have an error that causes revs to change
Old 07-01-2020, 04:11 PM   #7
Daily86
Daily86's Avatar
This fixed it. Thanks.
Old 07-05-2020, 09:44 PM   #8
powerwdp
Drives: 2018 Toyota 86
Can you let me know how your MAF correction table look like? I had the same issue and after updating it rev will bounce a little after cold start in parking gear..
Thanks
powerwdp is offline   Reply With Quote
Old 07-06-2020, 08:20 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Go to the link I posted above....
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-06-2020, 10:30 AM   #10
Daily86
Daily86's Avatar
I've been experimenting. This is what is good for me. Look at the link that Kodename47 posted.
Old 07-13-2020, 08:41 PM   #11
powerwdp
I'm the op of that post.
Just want to solve the still existed one-time small bump, seems like the only major difference between mine and yours are the number "9" at last two rows. do you intend to put the 9 there or it just liked that at beginning?
Old 07-14-2020, 04:30 PM   #12
Daily86
Daily86's Avatar
Didn't notice that. Yeah, I think I did that. I've been using the table like this and doing fine. When I get a chance I'll try to change it to a 7 and see if there is any difference.
Sent from my SM-G930V using Tapatalk
Old 11-27-2020, 01:34 PM   #13
Daily86
Daily86's Avatar
Forgot about this thread. I changed the "9" to a "7". No difference. I'm pretty sure I made those a "9" by accident.
MPG/Idle issue!! 12foot Issues | Warranty | Recalls / TSB 33 04-03-2019 03:01 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Another Idle Issue? amacadam Issues | Warranty | Recalls / TSB 1 11-04-2014 05:35 AM
Possible Idle Issue???? Help please soontobrz Issues | Warranty | Recalls / TSB 2 07-08-2013 07:34 PM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
