| DIY (Do-It-Yourself) Guides For all DIYs. |
Removing and Replacing your BRZ/FR-S Accessory Belt
GrimmSpeed DIY Guide Series
Removing and Replacing your BRZ/FR-S Accessory Belt Updated 6/29/12 Introduction: This guide will illustrate how to inspect and change the accessory belt on your BRZ/FR-S. Tools: The tools listed below are suggested for this task (figure 1). Optional tools are noted. - Needlenose Pliers - ¼ in Ratchet - ¼ in Extension - ¼ in drive deepwell 10mm socket - 3/8 in Ratchet - 3/8 in 12mm socket - Screwdriver ![]() Tips: Procedure: 1. Begin by following our intake removal guide to expose the belt. ![]() 2. Next, remove the black covers on the alternator and power steering pump. ![]() ![]() 3. Use your 3/8in drive 12mm socket and wrench on the tensioner pulley as shown below. This will release tension on the belt and you should be able to slip it off of the idler pulley with no issues. After the belt is removed, you can slowly bring the tensioner back. ![]() ![]() 4. Easy as that. Re installation is just the reverse. Remember to double check that the belt is properly routed and seated in each pulley before starting the car. Last edited by GrimmSpeed; 02-10-2014 at 02:19 PM. |
| The Following 11 Users Say Thank You to GrimmSpeed For This Useful Post: | ATL BRZ (07-06-2012), baldolera (08-17-2012), civicdrivr (06-30-2012), cmspooner (07-27-2012), ddevl_86 (03-25-2021), FRSPirate (06-29-2012), kwood9000 (07-23-2012), neutron256 (07-23-2012), Sportsguy83 (06-30-2012), Style (08-02-2012), ts87 (12-16-2013) |
#2 |
NW Region Moderator
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
#3 |
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
FYI to anyone trying to attempt this, pulley is pushed down as if you are trying to tighten the pulley to remove the tension not the way shown on the picture.
-Alex
05 Raven R6 13 Raven FRS M/T |
| The Following User Says Thank You to FRSPirate For This Useful Post: | ATL BRZ (07-23-2012) |
#4 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
To clarify, you're saying the tensioner pulley is loosened with a clockwise (righty tighty) effort with a socket wrench? Weird but thanks for the tip.
#5 |
Señor Member
Drives: 2013 SSM DZE BRZ
#6 | |
EDIT: Pictures have been fixed thanks to Matt from GrimmSpeed. Info above is correct!
-Alex
05 Raven R6 13 Raven FRS M/T Last edited by FRSPirate; 07-24-2012 at 02:20 PM. |
#7 | |||
Matt |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | FRSPirate (07-24-2012) |
#9 |
Drives: 2013 BRZ, 2002 WRX
I may have inadvertently over-tightened the v-belt tensioner when releasing belt pressure. Does anyone have the proper torque value for the tensioner pulley bolt?
Also, to be clear, this is reverse-threaded, correct? Thanks!
#10 |
Drives: 2013 frs
I was just reading thru this and I think you made a mistake .. I believe the other black cover is for the a/c compressor ..Please correct me if I'm wrong
Thanks |
#11 |
Drives: 2013 JRSC Firestorm FR-S
Just did it. It's a 14 mm wrench and socket for the tensioner not a 12 mm.
| The Following User Says Thank You to Germanjap For This Useful Post: | Turdinator (11-15-2016) |
#12 |
Drives: GBM Subaru BRZ
Any chance anyone knows the part number of the tensioner
pulley bolt? I've tried googling it but all I can find is the idler pulley bolt. I sheared mine off. |
#13 |
Drives: 2015 FR-S
I would recommend reaching out to Toyota/Subaru dealership, they should know the part number...
| Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete | GrimmSpeed | DIY (Do-It-Yourself) Guides | 99 | 01-25-2015 02:24 AM |
| Seat belt issues | skoodge | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 08-04-2014 04:41 PM |
| STi's newest accessory!!! | Godzpeed | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 07-08-2012 02:21 AM |
| Red Seat Belt - where to get? | MarkMash | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 06-24-2012 12:55 PM |
| You wish you were this seat-belt! | YukiHachiRoku | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 05-03-2012 08:43 PM |
