#22023 |
![]() ![]() Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | humfrz (06-14-2020) |
#22024 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I'm more than content in giving up the FR-S and keeping the Frontier. Much easier to find another manual 86 down the line than a 2nd gen 2WD, King Cab, 6speed manual Frontier. I had to fly to North Carolina to get my Frontier...only one of a few in the country I could find specced as wanted and within my budget at the time I was looking some 3 1/2 years ago. I will miss the FR-S, but I like how I don't need to worry about a lift to do basically anything under a truck for maintenance.... just go right under it and do whatever maintenance work needs to be done. FR-S with a front lip is so freaking low a regular jack won't even fit under it... had to drive up on pieces of wood to fit a jack under it just for doing an oil change. And rear has to be lifted for differential fluid change, where with the truck you can do it as is on the ground.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
| The Following User Says Thank You to Vracer111 For This Useful Post: | soundman98 (06-14-2020) |
#22025 | |
#22026 |
Drives: 13 FRS
changed spark plugs last weekend but didnt drive it
this weekend replaced my leaking rear strut with a new OEM one (used the spring compressor tool to keep the same spring as they still had little milage on them) also did an on oil change. while doing the spark plugs i removed the stupid sound tube and plugged the hole in the passenger compartment absolutely love driving this car, felt amazing today after all that work also rewarded myself with a milwaukee 1/2 inch impact for future tire rotations/swaps
#22027 |
Drives: Scion FRS
Stay-at-Home...to install car parts
In this past month, installed TRD lowering springs, Konig Hypergrams 17x8 +40, VLand Headlights, replaced a broken wheel stud in the rear, and added duckbill spoiler.
Just smile and wave.......
#22028 |
WOW! Busy boy. Your car looks great!
#22029 |
Drives: 2016 Scion FR-S
Installed Cusco motor mounts today. About a week ago I installed the Perrin transmission support and also modified a whiteline transmission bushing to fit the Perrin support. Shit ton of NVH, but the car handles great and the driveline lash is gone. And the extra noise makes me smile like an idiot as it runs towards redline. I also installed a Fumoto drain valve and Cusco pedal about a week ago.
Sent from my SM-G960U using Tapatalk ![]() ![]() ![]() ![]()
| The Following 3 Users Say Thank You to Silviacrazed For This Useful Post: |
#22030 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
After having dealt with the horrendous brake squealing these past couple of weeks since installing Hawk HP+ pads, I'm happy to finally drive the car with extended studs and not-as-horrendous squealing after having added some lubrication all around! (not on the pads or the rotor themselves of course)
So now all that's left is to finally give the car a proper wash and start thinking about more mods. |
| The Following User Says Thank You to KR-S For This Useful Post: | humfrz (06-19-2020) |
#22031 | |
#22032 |
Drives: GR Corolla
Started daily driving the FRS again.
#22033 | |
Drives: Scion FR-S Series 10 #2462
#22034 | |
Sent from my SM-G960U using Tapatalk |
| The Following User Says Thank You to Silviacrazed For This Useful Post: | MJones_RB (06-22-2020) |
#22035 |
Why don't you folks just weld the engine to the frame (body), weld the transmission to the engine, and weld all the other parts of the drive train together then weld that all up to the transmission? -
| The Following User Says Thank You to humfrz For This Useful Post: | Silviacrazed (06-20-2020) |
#22036 | |
Drives: 2018 BRZ
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | MJones_RB (06-22-2020) |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
