Crank but no start after clutch rep.
As the title states, my engine will turn over but not start. The only thing I can think of is the wire that comes off of the harness near the crank (it's an L shaped bracket that appears to be a ground). I cant for the life of my remember where it goes.
#2 |
If it's a ground then stick it anywhere with good metal to metal contact
Sent from my ONEPLUS A5010 using Tapatalk |
| The Following User Says Thank You to Ashikabi For This Useful Post: | alphasaur (06-19-2020) |
#3 |
Drives: FRS
I think the one you’re talking about goes right over the starter bolt hole and the trans/starter bolt holds it down
| The Following User Says Thank You to vladniko86 For This Useful Post: | RWD fun (06-18-2020) |
#4 |
#5 |
Drives: Crapcan
Make sure the DI module bolts are tight.
If you need pictures as an example let me know. I have my car handy and partially torn apart.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | RWD fun (06-18-2020) |
#6 |
#7 |
Drives: Crapcan
#8 |
So my throttle body makes a humming noise as long as the key is in the "on" position. I've never noticed it before but I don't think it's normal.
Also, say I had a bad coil or plug, the car would probably start even if it was with a misfire? |
#9 |
Drives: Crapcan
Bad coil or plug would misfire and likely still start. It would give you a CEL usually too.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (06-18-2020) |
#10 |
How can i check for spark? Doesn't seem practical the old school way because of the flat 4 configuration
#11 |
Drives: brz
Check fuses.
Check all the elec plugs on passenger side of engine. A few other things that will keep it from starting is intake cam sensors, direct injection fuel pressure sensor and maybe crank sensor. I know this is stupid but did you put the crank reluctor on correct? It happens. Last edited by solidsnake11; 06-19-2020 at 12:49 PM. |
#12 | |
#13 |
| No start No crank Anti-theft blinking | 02maher | Issues | Warranty | Recalls / TSB | 37 | 05-18-2020 10:00 AM |
| Car won't start - doesn't try to crank at all, but lights are working HELP | cdo221 | Issues | Warranty | Recalls / TSB | 28 | 06-06-2018 07:30 PM |
| Crank No start (Not battery issue) NEED HELP | cnxmist | Issues | Warranty | Recalls / TSB | 19 | 07-28-2017 06:44 AM |
| Car won't start, won't crank, no ecu communication | redlined600 | Issues | Warranty | Recalls / TSB | 10 | 07-09-2016 01:55 PM |
| No crank no start issue | *KID* | Issues | Warranty | Recalls / TSB | 3 | 09-29-2014 07:22 AM |
