| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Definitely not the OEM plug.
#16 | |
Drives: MDX, Camry
Sent from my Pixel 3 XL using Tapatalk |
#17 |
Drives: 2014 MY15 86 GTS
The other reason not to use a torque wrench is its got oil on the thread so your going to over torque the bolt.
Plus its not a critical bolt ie. head bolt. |
| The Following User Says Thank You to Halo_2 For This Useful Post: | soundman98 (03-17-2020) |
#18 |
Drives: 2014 DGM BRZ
Just to circle back and close the thread on this:
I removed the (non-OEM) drain plug and drained my oil. Upon inspection, it looks like the excessive force I put on the bolt by using my 1/2" drive made the drain plug cave in on itself. I installed the fumoto valve according to the instructions and the leak seems to have stopped...hopefully forever. I was/am however worried I cross-threaded the threads but I'll keep an eye on it. Thanks all for the input. Hopefully others can learn from my mistake! |
#19 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | humfrz (06-16-2020) |
#22 |
#23 |
Drives: car
fumoto valve ftw
| The Following 2 Users Say Thank You to radroach For This Useful Post: | humfrz (06-18-2020), soundman98 (06-18-2020) |
#24 |
fumoto valves are for woosies. -
![]() Real men use this. -
| Finally fixed the oil leak - Warning for those still using OEM drain plug/gasket. | lupindub | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 02-25-2016 08:47 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 08:36 PM |
| Best magnetic drain plug? | FR-Sizzle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 09-28-2015 02:07 PM |
| Oil Drain Plug Size | jjkerr626 | Engine, Exhaust, Transmission | 3 | 11-28-2014 07:20 PM |
| Help! - slow leak from oil drain plug | amram | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 05-28-2014 03:42 PM |
