Old 06-14-2020, 06:03 AM   #1
Dom2497
Drives: Full HKS GT86
Ecutek - Using rear 02 for a different sensor
As per title, I am using the rear 02 sensor for a oil pressure input. All ok but I can see the voltage feed to the sensor which I am taking from the rear 02 osciliates. Reading around it's because I am using the o2 heater to power the sensor and this uses PWM to cycle the heater on and off normally.
If I power the sensor from a direct feed to the battery it works as expected.
Does anyone know how I can power the sensor without this PWM / voltage oscillation? Is there a way I can turn it off in Ecutek?
I can see other people have run the oil pressure sensor solely off the rear 02 socket so I know it's possible.
Sent from my SM-G950F using Tapatalk
Dom2497 is offline   Reply With Quote
The Following User Says Thank You to Dom2497 For This Useful Post:
nerve86 (10-03-2022)
Old 06-14-2020, 06:55 AM   #2
tomm.brz
Drives: brz 2017 hksv2
i do this: Do not use custom map for that
Use Ecutek COOLANT PRESSURE (CP) sensor
you can scale your sensor there and apply SMOOTHING
put a smoothing of 0.2 (1 is no smoothing) and you ll have your output value much more stable and then with custom map you will refer to COOLANT PRESSURE to build a failsafe if you want
if you need help i can do it for you, otherwise ask your tuner to use the CP
same signal of oil pressure from rear 02, one with smoothing one without
edit: sorry didn t read well. you should NOT power your sensor with rear o2, you need a stable 12v possibly on key, change it ASAP
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
Dom2497 (06-17-2020), nerve86 (10-03-2022), Trap63 (09-03-2023)
Old 06-14-2020, 08:39 AM   #3
Dom2497
Thanks for the reply, absolutely makes sense what you're saying so will switch over to cp sensor. I will get digging to find out what wiring I need to do to use the new input.
Old 06-14-2020, 08:50 AM   #4
Dom2497
A just seen I can choose the source and can pick 02 sensor
tomm.brz (06-15-2020)
Omni 3bar map sensor values for ecutek Agent_D Software Tuning 9 07-17-2017 09:32 PM
Rear parking sensor Eighty 6 Scion FR-S / Toyota 86 GT86 General Forum 22 03-06-2016 11:05 PM
WTB: OEM Rear Oxygen (o2) Sensor xjohnx Want-To-Buy Requests 5 04-07-2014 10:32 PM
Ecutek Map Access, data logging Vs. obd2 sensor lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 01-06-2013 02:56 PM
