#169 | |
If things reach a point where ever single EMT is spending every working minute transporting elderly people to medical attention then the shit has truly hit the fan and Florida will be an empty wasteland in a week so you can just track on the streets. I didn't say it was a great idea just that as far as social distancing goes then tracking would be one of the best sports.
| The Following User Says Thank You to Tcoat For This Useful Post: | Opie (11-05-2020) |
#170 |
Drives: 2020 GMC Canyon Denali Diesel
Track should setup a key card and transponder system. Key card would keep you off track until your proper run group, transponder would tell them if & where you had an issue. Less manpower....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#171 |
Lightened the car by a little more than 30lbs on Saturday. Removed the following unnecessary parts:
Driver & Passenger Side Curtain Airbags, Passenger Dash Airbag, Airbag Controller (Computer), Both Front Seat belts, Headliner, Antenna Wiring harness, Dome light wiring harness, A-Pillar trim, B-pillar trim, C-pillar trim, Dome light, Bluetooth mic, Headunit, GPS antenna & bracket, 8 Speakers, Amplifier and several miscellaneous brackets. Car should be down under 2,700lbs now.
| The Following User Says Thank You to Opie For This Useful Post: | SuperTom (04-17-2020) |
#172 |
Stole Dave-Ror's taillights...
![]() And filled the big empty radio hole with a delete plate.
| The Following User Says Thank You to Opie For This Useful Post: | new2subaru (04-26-2020) |
#173 |
Weight Weenie
Drives: 15 FR-S
#174 |
From Toyota, P/N:55522-52020
#176 |
So am finally headed to Sebring tonight for the weekend and get to try out all these changes! It's gonna be humid, hot and rainy...just like every other summer day in Florida but it's gonna be fun!!
Will be out there with my friend Aaron, owner of Opie & Dave-ROR's rebuild #6 @Dave-ROR says it's too hot....or he is just too slow...
| The Following User Says Thank You to Opie For This Useful Post: | Code Monkey (05-29-2020) |
#177 |
Ran consistent 2:38's at Sebring this past weekend, put down a new PB of 2:38:33 on an old set of RE-71R's I used on Saturday with thinking it would rain but was Humid & Super Hot instead.
Sunday was dry so I ran a set of brand new R-Comp Hoosiers for the 1st time and set another PB of 2:37:88. I know there is a bunch more time with those tires as they grip like nothing I've tried before! ![]() Parked the car after a few issues, thanks to the Sebring bumps LOL: Have a slight tire rub in turn 1 I need to address since I'm taking it much faster than before, going to raise the coil-overs 1 turn at all 4 corners to maintain the corner balance. Right end plate on the Big Wang lost a screw and the plate was dangling for a few laps. Steering wheel became way off center during the day, I assume something is loose...or bent. Need to inspect to determine. Was a super fun weekend, would've been a perfect weekend if it wasn't so hot & humid. Have videos I'll get uploaded later this week!
| The Following User Says Thank You to Opie For This Useful Post: | Code Monkey (06-01-2020) |
#178 |
Drives: 2013 BRZ Limited 6MT
Lmao you mention the heat and humidity like you dont already live in Florida. Its summer, mate!
Which Hoosiers are you using? What made you want to buy some brand new sticky bois if you're not doing NASA or SCCA? |
#179 |
Drives: Crapcan
This has been a constant issue for me as well the last couple years. Alignment feels fine but wheel will slowly become off center. I was thinking it could be the steering rack bushings degrading. Forgot to look last time I was under the car.
#180 | |
Hoosier R7's - They were a gift...and now I'm addicted to the purple crack....
#181 |
Interesting....that seems to be my case, car still tracks straight and alignment seems fine (no pull, etc) just the wheel is way off center....I could go around turn 6 (right turn) and the steering wheel was straight...down the straightaways the wheel was at the 10:00 position...
#182 | |
Drives: Crapcan
| NORGP GT86 just for Track Rebuild | Panamaniac | Member's Car Journals | 25 | 12-06-2019 09:41 AM |
| History of my GS-R.. and rebuild.. my now-current track car. | Dave-ROR | Other Vehicles & General Automotive Discussions | 35 | 12-12-2013 09:02 PM |
| MVP Track Time 2013 Road Atlanta Track Dates | Feffman | Southeast | 7 | 11-05-2013 12:36 PM |
| MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 02:39 PM |
| FS: 2013 Totalled BRZ FS (~5,000 miles) | eklipz98 | Northern California | 45 | 02-03-2013 02:16 AM |
