| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Toyota 86 GTS
Water drip normal?
Just been out driving for a few hours and noticed when I got home a leak under my car. I had the AC on the whole time but can't remember noticing any leaks under the car before (that being said I don't exactly check that often).
Anyway I can't tell if it's just condensation or an actual leak. There is a hole I think? where the leak is coming from but I can't tell whether that's an actual hole caused by something or if it was there before because it's more of a circular indentation into the lower part of the car that looks man-made rather than a rock or something hitting it, creating a hole. Pretty sure it's water, clear and doesn't smell. Do I need to be concerned? Should I just plug the 'indentation' myself with some kind of glue? Also when I say leak it's more like a singular drop every few seconds or so, not a continuous stream. Added the blurry image because I noticed the water built up around that part as well EDIT - Been home for about 15-20 minutes now and it's still dripping but barely, like a singular drop every 30 seconds or so ![]() ![]() EDIT Found another indentation like it on the opposite side of the car in a different spot so i was right about them being man made but now confused as to why they're there and if I still should be concerned about the drip. This one isn't showing any signs of a leak
#2 |
Drives: 2016 Scion FR-S
A/C systems always drip. It's perfectly normal.
Sent from my SM-G960U using Tapatalk |
| The Following 4 Users Say Thank You to Silviacrazed For This Useful Post: |
#3 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
It's condensation from the A/C coil under the dash.
If it wasn't vented under the car, it would be dripping on your passengers feet. When hot moist air goes over the cold coil, the water falls out the bottom. Most kitchen fridges have a drip tray under them to water the dust bunnies.
"I gotta rock." -- Charley Brown |
#4 |
The Dictater
Drives: '13 Red Scion FRS
Here's another "it's normal" if you needed one.
| The Following User Says Thank You to Spuds For This Useful Post: | Sam86 (05-26-2020) |
#5 |
Drives: ‘13 FRS
Uh Oh.
Does your engine sound smooth? Or does it kind of make a ticking noise?
| The Following 2 Users Say Thank You to NWFRS For This Useful Post: | Silviacrazed (05-26-2020), Ultramaroon (05-26-2020) |
#6 |
Had no issues with performance or any weird sounds. I mean I suppose it makes a ticking noise once I turn off the car but that's temporary and just assumed it was the engine cooling down as I don't hear it when driving or if the car is idling
#7 |
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
#8 |
LOL
Ignores the three proper answers and homes right in on the troll response. It is fine as long as it isn't combing out the tail pipes.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Hoahao (05-26-2020), NWFRS (05-26-2020), Silviacrazed (05-26-2020), soundman98 (05-26-2020), Ultramaroon (05-26-2020) |
#9 |
Drives: 2016 Scion FRS Halo
Your car is probably fine.. more than likely it's AC condensation drip.. touch it, smell it.. smell petroleum based? IF not, 99% sure that's what it is.. the pinging sound is usually the different metals.. cooling down at different rates from what I've gathered.. perfectly normal.
#10 |
ProCrastinationConsultant
if there's any comb's involved, you're in serious trouble. though i'm not sure to recommend a barber or a mechanic.
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (05-26-2020) |
#11 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Sapphireho (05-26-2020), soundman98 (05-26-2020) |
#12 | |
The pinging sound is the specifically the exhaust cooling and contracting. It happens on every car ever made and was only a troll post by NW.
| The Following User Says Thank You to Tcoat For This Useful Post: | NWFRS (05-26-2020) |
#13 |
Rust bucket enthusiast
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | Spuds (05-26-2020), Ultramaroon (05-26-2020) |
#14 |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | DarkPira7e (05-26-2020), soundman98 (05-26-2020) |
| Help - Condensation/Water Drip Inside Vehicle - **VIDEO** | Timmy_Jones | Issues | Warranty | Recalls / TSB | 10 | 08-09-2018 02:13 PM |
| Is this engine noise normal? (Consensus - normal) | StraightOuttaCanadaEh | Issues | Warranty | Recalls / TSB | 31 | 02-05-2018 04:01 PM |
| Is this normal? | Cedars | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 12-03-2015 09:33 AM |
| How to remove drip rails? | sydney86 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-13-2013 01:58 PM |
