Noise in the Engine
Hello Guys,
I need your help in this issue I've changed the spark plugs and cleaned the 8 injectors by specialist, After that there was a loud knocking noise or something blowed up in the engine on rpm 2-3 and there is almost no power. |
#2 |
Drives: 2013 frs raven
Was your engine part of the valve spring recall? What year is it?
#3 |
Nope, 2013
There was a valve spring recall in america? |
#4 |
Yea the 13' scions had it. Don't believe the Subaru or Toyotas did.
Not really sure what else to give. What happened leading up to this issue? |
#6 |
It happened straight away after replacing the spark plugs and cleaning the 8 fuel injectors.
#7 |
#8 |
They all had it. They are all the same bloody car.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkPira7e (05-13-2020), Ultramaroon (05-13-2020) |
#9 |
Make sure they put all the plug wires/coil packs back in the right place
#10 |
Rust bucket enthusiast
Make sure you reconnected your coilpacks and are grounding out the DI harness with the screws
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tcoat (05-13-2020) |
#11 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
How straight away after did it happen? Like right on start-up or first drive? Did something fall into the intake through injector hole? Maybe there was that one screw you couldn't find?
Work Hard. Play Hard.
2016 Oceanic |
| The Following User Says Thank You to ActionMaxon For This Useful Post: | soundman98 (05-13-2020) |
#12 |
No fuel smell at all
#13 |
At happened after 2 days around 80km
#14 |
wait.... 8 injectors? Loud popping sound, maybe?
| Engine noise | Antisocialspeed | Engine, Exhaust, Transmission | 4 | 09-20-2019 10:06 PM |
| Engine/Transmission noise | N1rve | Issues | Warranty | Recalls / TSB | 48 | 05-06-2018 10:17 PM |
| Really odd engine noise | Deadspool | Engine, Exhaust, Transmission | 52 | 03-10-2014 12:43 PM |
| Another Engine noise | Vegas86 | Issues | Warranty | Recalls / TSB | 4 | 10-09-2013 12:30 PM |
| Engine noise | somejace | BRZ First-Gen (2012+) — General Topics | 4 | 09-19-2013 06:39 AM |
