#71 |
Drives: '15 BRZ RA
Do you have a picture of the final result? Just want to check how much they work ...
#72 |
Drives: brz 2017 hksv2
i do have them, driver side still sags like they aren't there as before just after 1 month
but well, not much |
| The Following User Says Thank You to tomm.brz For This Useful Post: | nikitopo (06-05-2019) |
#73 | |
Drives: 2013 WRB BRZ
![]() Sent from my iPhone using Tapatalk
#74 |
Senior gif poster
Drives: 2013 Asphalt FRS
I was looking for a while for this post, and I just wanted to throw a new post in here for this thread to get more visibility.
#75 |
Drives: Whiteout FRS
Bump. Does anyone know if Toyota has a TSB for this?
#76 |
Drives: '15 BRZ RA
I still have this bumper plate. Waiting to install it when I'll remove the bumper at some point of time. Not so urgent currently ..
#77 |
Site Moderator
Drives: ichi 86 Project
How many did you ordered? 2 or 4?
#78 |
Drives: '15 BRZ RA
| The Following User Says Thank You to nikitopo For This Useful Post: | ichitaka05 (05-02-2020) |
#79 |
Site Moderator
That's what I was thinking as well. I'm replacing my front bumper, so mind as well get that plus new support rails to get it tightly fit again.
#80 |
Drives: 2016 Scion FR-S
#81 | |
Drives: 2013 WRB Subaru BRZ Limited 2.0
Mine was totally fine (MY2013) until just recently. Might as well buy and install these clips before it happens to you! |
#82 |
My 6 year old, 150,000 mile, lowered FRS, that bounced the bumper off any incline over about 20 degrees and many a speed bump was still 100% fine. In fact when I sold it one of the first things the guy said was "Hey, it doesn't have bumper gap".
| The Following User Says Thank You to Tcoat For This Useful Post: | theneptune86 (03-08-2021) |
#83 | |
and an update: I installed these and it still didnt fix it, so it must be the brackets
| The Following User Says Thank You to jtiptonk For This Useful Post: | Tcoat (10-03-2020) |
#84 |
I have the dreaded bumper gap on my 2013 BRZ. I bought two of these metal pieces (57722CA030 - $11 each from the dealer) and new bumper brackets (57707CA050 & 57707CA040). The fix was successful for one day and now have the gap again. Is there no permanent solution?
| Tags |
| 57722ca060 plate bmpr sd, brz, subaru, zc6 |
| DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 | Trap63 | DIY (Do-It-Yourself) Guides | 0 | 06-14-2018 04:52 AM |
| SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017 | Trap63 | Issues | Warranty | Recalls / TSB | 10 | 06-03-2018 11:33 PM |
| SB18-077 *BRZ ALL, Flywheel assy and ball bearing | Trap63 | Issues | Warranty | Recalls / TSB | 0 | 05-29-2018 03:26 AM |
| Someone recognizes this rear spoiler? | pepe | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-12-2016 05:57 AM |
| USB flash drive for mp3's, only recognizes 61 songs per folder? | Suparu | Electronics | Audio | NAV | Infotainment | 6 | 08-22-2015 02:15 PM |
