Old 04-12-2020, 01:30 PM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've been using this off brand baffled catch can since the before they had other versions. I put a bit of brillo pad in the baffle compartment and teflon tape on the dipstick and main body threads to ensure no vacuum leaks for the past... 5-6 years? Pretty happy with it.
https://www.addw1.com/collections/all-oil-catch-can
I'm pretty certain you can find them much cheaper than on the website. Possibly amazon. Minor flaw in the seal, but easily remedied.
Intent > Content
Old 04-12-2020, 08:52 PM   #16
86MLR
86MLR's Avatar
Fuel foam works a treat, I've never been confident that little bits of steel won't pass through when using steel wool.
Old 04-12-2020, 09:42 PM   #17
86MLR
86MLR's Avatar
This, plus this, plus some 12 an fittings and fuel foam.
Use a big holesaw on the top to install the "fuel cell lid" (access for putting in fuel foam and servicing the AOS i.e. cleaning).
Replace the surge tank small fittings with 12an for the breather feeds.
Drains, fit a valve on one for draining and block the other.
Once fabricated paint with VHT krinkle paint.
Shouldn't cost more than around $200, lots of volume, lots of direction changes.
I've never seen a real racecar, apart from shop cars, with these brand name AOS/catch cans, they all use custom made items with volume, baffles and other internal forms of media for stripping oil.
Opinions may vary
Like the performance of some AOS/catch cans.
The Following User Says Thank You to 86MLR For This Useful Post:
scottryan (04-12-2020)
Old 04-12-2020, 11:09 PM   #18
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Hell yeah! I'll even slap a Lambo logo too.
Hell. I'll even leave the Coke logo on as well.
Astounding customer service
scottryan is offline   Reply With Quote
Old 04-12-2020, 11:11 PM   #19
scottryan
Financial Distress
scottryan's Avatar
Originally Posted by falcon_wizard View Post
It you set it up properly the first time, you won’t regret it. With the added power of E85, it may be worth putting the wagner adjustable pcv valve on your list as well. People talk a lot about catch cans/aos for handling blow by, but few people talk about managing crank case pressure, which robs power but can also cause reliability issues. Particularly if go plan to go FI, it will protect your engine but also give you better performance/throttle response.
Had I known what I know now, I would have done this a lot time ago.
See an example on my post here: https://www.ft86club.com/forums/showthread.php?t=139784
Appreciated my man, I'll look into that 100%
Old 04-12-2020, 11:42 PM   #20
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Nothing. You do not need one with This platform unless you have a MAJOR turbo setup.
Save your money.
Old 04-13-2020, 06:02 AM   #21
solidONE
solidONE's Avatar
dont use steel wool.
Brillo is a brand I think, but this is the stuff:
Fuel foam even better you can make it the exact shape of the baffle chamber. But, I dont have that stuff laying around.
Intent > Content
Old 06-01-2020, 01:34 AM   #22
airrick
Drives: TRD R.S. 1.0 FRS
I read all of that. And your thread, yea i think most people dont have the know-how to do stuff like this. If only my tuner does. I will try it regardless
Why is this the first thread im learning of this?
airrick is offline   Reply With Quote
Old 01-05-2021, 05:32 AM   #23
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Would this be considered a good item?
Laile Beatrush oil catch can with drain back via the oil cap.
https://www.japanparts.com/parts/detail/50405
Thanks.
Thefalls is offline   Reply With Quote
Catch can recommendations for Vortech supercharged? jstn Forced Induction 6 02-14-2020 08:47 PM
Catch Can recommendations for FI FullTuneZN6 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 06-19-2016 02:50 PM
Lip Kit recommendations scottxnizzle BRZ First-Gen (2012+) — General Topics 18 03-29-2015 08:14 PM
Recommendations? E403Q Engine, Exhaust, Transmission 8 06-09-2014 03:11 AM
PDR Recommendations in NY or CT TommyFive NY / NJ / CT / PA 6 09-10-2013 04:48 PM
