#43 | |
Drives: brz 2017 hksv2
with 8-9psi, his use of stock PI injector on e85 was already on the edge he has plenty of power on e85 and high timings and then he also suddenmly switch to 91oct e10 The slightly rixher afr needed for 91 makes the use of PI even more extreme so that final ign timing went of course down and I set them to the edge of knock and then he asked me if he would make more power with an electronic controller and raising the boost, and I answered to him that with e85 would probably be no problem, since it still had some headroom in timings with the base boost, but I also said that raising boost, with oft and stock injectors and flex fueling, would create problems because injectors are maxed out and I wasn t comfortable in tuning that anymore With ecutek and/or bigger PI i would have no problem in saying to him to raise boost |
#44 |
Most folks only talk about their peak boost, and peak power, whether they're turboed or supercharged. It's extremely rare to see someone speaking otherwise. Likewise, most turbo setups have a flat or falling boost curve, not a rising boost curve.
#45 | |
#46 |
Rust bucket enthusiast
This is just it. With my tune, we delay boost intentionally. It comes in at 7 psi and is only at 10psi by 4,500rpm. It ramps up to 17psi between 5-7500 to make a smooth curve. Staying out of boost below 3500 is also essential in my opinion, for stock motor
| The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
#47 | ||
| The Following User Says Thank You to CSG Mike For This Useful Post: | Irace86.2.0 (04-12-2020) |
#48 | |
Drives: Q5 + BRZ + M796
That chart might be old like before direct injection and high compression engines were more prevalent. It definitely doesn’t apply to built motors on race fuel. I know lots of people do built motors with modest goals, or they do it for security or insurance, but I couldn’t resist more boost if I had a built motor. I would run progressive boost, boost by gear, dual boost maps and boost by ethanol level. Like couldn’t he run a lower boost map for 91 or when the flex fuel is closer to E10 and run a higher boost map when it is over E45 or something? Like I’ve seen plenty of setups that automatically switched to ones that had a toggle or button to people running manual boost switches. Is OFT tune the problem for him?
#49 | |
#50 |
Wastegate is about 9 psi, so no and without ecutek i couldn t set a variable boost depending on fuel so i gently declined the tuning with more boost
Only way i thought was with a manual ebc but i mean, would be pretty rude to have to remember each time to set a different boost (not even precise then) when changing fuel Last edited by tomm.brz; 04-12-2020 at 03:15 AM. |
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | CSG Mike (04-12-2020), Irace86.2.0 (04-12-2020) |
#51 | |
With e85 we could definitely (with an eye to the PI opening time and the use of a little leaner afr) add an ebc and raise the boost despite the high compression ratio, but the problems come out when he switches to 91 It needs quite a richer afr (even if e85 requires at least 20% more fuel compared to e10, that becomes a problem anyway because PI is still to extreme uses) to cool things up and PI becomes maxed out and it requires too much of a reduction in ign timings that, other than being TOO much of a reduction, it basically knocks randomly in an uncontrolled way. And i had no way of reducing further timings against higher gears Give me his tune again, with a bigger PI and an ebc hooked into Ecutek instead of OFT, and better things come out I think CSG Mike can imagine the pain in the ass this sitaution and the use of openflash (so no ecutek tricks) to tune this car in particular is Most tuners wouldnt even start to tune a FI Flex car that has stock injectors... and they REQUIRE ecutek Trying to maximize performance is cool but i surely don t try to do it in this situation... at least he won t bend a rod while he enjoys a perfectly running flex turbo Frs, and in the meanwhile he can upgrade injectors and switch to ecutek Last edited by tomm.brz; 04-12-2020 at 03:35 AM. |
#52 |
Nothing is secret. It's just a matter of asking the right questions, because if you ask a general question, you'll get a general answer.
Or you can just watch my videos. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Irace86.2.0 (04-12-2020), tomm.brz (04-12-2020) |
#53 | |
Sounds like it's time to change tuning solutions, since relative to all the other money spent on the build, it seems odd to penny pinch on such a critical item. |
#54 |
thanks for the answers and the understanding
#55 | |
![]() ![]() ![]() Butttttt wwwhhhyyyy? Why build an engine to use open flash and stock injectors?! Like I understand the idea of a tight budget, but a good tune and proper injectors are just as good insurance as a built motor, and they are cheaper. That dude needs to make the switch to ECUTEK and make injectors his number one priority.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | CSG Mike (04-13-2020) |
#56 |
maybe he will do, who knows
![]() at least now his car is running safe and good |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Irace86.2.0 (04-12-2020) |
| Tags |
| 500 whp, 550 whp |
| Who makes a good AOS for our cars? | D K | Engine, Exhaust, Transmission | 17 | 05-28-2014 04:24 PM |
| GReddy Scion FR-S Makes First USA Public Appearance at Cars & Coffee in Irvine, CA | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 172 | 01-16-2014 02:28 AM |
| How do I use A2DP conveniently and reliably? | qoncept | Electronics | Audio | NAV | Infotainment | 6 | 06-04-2013 01:35 PM |
| Got a ride in a 550hp C5 Vette...meh. | Superhatch | Other Vehicles & General Automotive Discussions | 8 | 11-06-2012 03:32 AM |
| Aftermarket hood supports | fasteddy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 10-14-2012 12:01 AM |
