Old 04-08-2020, 10:43 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Catch Can recommendations?
I feel like for a catch can there isn't like a crazy front runner to go with, so what would you folks recommend? Thanks in advance!
scottryan is offline   Reply With Quote
Old 04-08-2020, 11:59 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Are you turbo/super charged? If yes go ahead
If not, send me $100 and I'll getto rig a Coke can with any cool manufacture logo you want.
The Following User Says Thank You to Mr.ac For This Useful Post:
Clutch Dog (04-09-2020)
Old 04-09-2020, 01:21 AM   #3
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Send me 100 bucks and ill sell you my racer X catch can not even joking.
but yeah a coke can with some wire scrubbies works just fine
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Mr.ac (04-09-2020)
Old 04-09-2020, 07:51 AM   #4
falcon_wizard
Drives: BRZ 2013
I have been very pleased with the Verus Engineering AOS, in a drain back configuration so there is no need to drain it. It acts as a dual aos setup, and can be heated as well. A bit pricier, but very well designed. As indicated above, unless you track your car, I would not expect it to be needed for stock NA setup but definitely recommend for FI and a must for built engine. For high HP setup, (say above 250whp) I would recommend an adjustable pcv (wagner) valve with a positive (not passive) ventilation setup as well, to ensure the block is well ventilated and does not build pressure in the crankcase.
falcon_wizard is offline   Reply With Quote
The Following User Says Thank You to falcon_wizard For This Useful Post:
TurboBRZ_UAE (10-10-2023)
Old 04-11-2020, 12:14 PM   #5
scottryan
Financial Distress
scottryan's Avatar
$120 and you slap on a ferrari logo????????
Old 04-11-2020, 12:21 PM   #6
scottryan
Financial Distress
scottryan's Avatar
Thanks for the recommendation man, yeah so I am tracking the car often in the summers and there are plans for FI in the coming future, so I decided to order an air/oil separator instead so I can cross that off the supporting mods list. Overkill no doubt considering I'm only on Stage 2+ E85 but still works nonetheless..... might still go for the coke can special tho.
Old 04-11-2020, 02:20 PM   #7
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Hard to pass up that Ferrari logo.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
scottryan (04-12-2020)
Old 04-11-2020, 03:14 PM   #8
radroach
Drives: car
Avoid the cheaper ones. I bought an older unbaffled mishimoto catch can and realized it would be useless, never installed it. No way was I was going to put up with nasty rusting catch-can media / steel wool.
Car consumes only 1/2 quart in 3000 miles unmodified at 120k miles. So I have no need for it.
The Following User Says Thank You to radroach For This Useful Post:
Old 04-11-2020, 06:38 PM   #9
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
$10 in parts from Harbor Freight
https://www.ft86club.com/forums/show...45&postcount=1
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
jordan7831 (06-04-2020)
Old 04-11-2020, 07:42 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I love the fitment of the Radium catch cans. I have the pcv side and it catches some stuff
Old 04-12-2020, 01:10 AM   #11
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Hell yeah! I'll even slap a Lambo logo too.
Hell. I'll even leave the Coke logo on as well.
Old 04-12-2020, 01:55 AM   #12
Infinity
Drives: 2016 Scion FR-S
The Verus AOS is the best, but it comes in at $550 with the drain kit, cam cover, and coolant add on.
The Radium is probably considered the next best, coming in at $250 with the drain kit.
The Racer X is a solid budget option which includes a drain valve for $180.
Infinity is offline   Reply With Quote
Old 04-12-2020, 04:09 AM   #13
86MLR
86MLR's Avatar
Catch can or AOS
Vented or recirculating
Drain back or catch.
Street car or track car.
Motorsport regulations required.
Size....from my old CAMS manual
15. if fitted with any crankcase breather discharging to the atmosphere, each breather be vented into a catch tank
of minimum capacity of two litres for engines up to 2000cc or three litres for over 2000cc. Regulations for
competitions on unsealed surfaces may waive this requirement;"
Most of the "shiny brand name" items are rubbish.
I've seen $500 brand name "AOS" that were pretty clean on the inside, but, the intercooler was full of oil.
Meh, I'm bored
The Following User Says Thank You to 86MLR For This Useful Post:
Old 04-12-2020, 10:05 AM   #14
falcon_wizard
Drives: BRZ 2013
It you set it up properly the first time, you won’t regret it. With the added power of E85, it may be worth putting the wagner adjustable pcv valve on your list as well. People talk a lot about catch cans/aos for handling blow by, but few people talk about managing crank case pressure, which robs power but can also cause reliability issues. Particularly if go plan to go FI, it will protect your engine but also give you better performance/throttle response.
Had I known what I know now, I would have done this a lot time ago.
See an example on my post here: https://www.ft86club.com/forums/showthread.php?t=139784
airrick (06-01-2020)
Catch can recommendations for Vortech supercharged? jstn Forced Induction 6 02-14-2020 08:47 PM
Catch Can recommendations for FI FullTuneZN6 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 06-19-2016 02:50 PM
Lip Kit recommendations scottxnizzle BRZ First-Gen (2012+) — General Topics 18 03-29-2015 08:14 PM
Recommendations? E403Q Engine, Exhaust, Transmission 8 06-09-2014 03:11 AM
PDR Recommendations in NY or CT TommyFive NY / NJ / CT / PA 6 09-10-2013 04:48 PM
