#43 | |
Drives: BRZ 2018
As handmade product every header is different as every BRZ/FRS is different, I think the rest of the exhaust plays a role and adds to the rubbing issue, although the only exhaust part I added is a Berk frontpipe. |
#44 | |
Drives: 2017 toyota 86
I have read some people having issues with certain frontpipes if they are either heavier, angled lower then stock, or installed lower, causing the overpipe to "droop" lower and hit. possibly something to look into. or see if you can reinstall frontpipe and bolt it to FP mount to have it higher and pushing overpipe up more. maybe pull catback in closer to "wedge" the FP up more. |
#45 |
It's made in Taiwan, I don't expect so much quality...
#46 |
Drives: BRZ 2018
They are quality products regarding welding and material but they have to adjust better distances and curves of each header to minimize rubbing issues and use better bolts/nuts, Tomei/Gruppe-s headers are made in Taiwan also and they are perfect quality imho!
#47 |
Drives: 2016 Scion FR-S
The header is $1700 without shipping or tax. Motor mounts are like $250-300. And you really need a ceramic coating, too. It is easily over $2000 to get this header properly installed on your car.
#48 |
Meh, just my two cents, during years I saw many different brands of exhausts, many of them of reputable brands, but when I saw Supersprint I was amused. But they are absurdly priced, and not so good for our cars...
#49 | |
It also used to be stocked by more vendors (now looks like only ace and csg) when other vendors had it they all have 10%+ off sales several times a year. If i waited 3 months i could have gotten mine to my door for 1215$. But I didn’t want to wait. But to be fair if the 1700$ ace was all that was available i would have got a EL JDL Last edited by 86TOYO2k17; 04-04-2020 at 01:17 PM. |
#50 |
Drives: Crapcan
LOL. That was pretty ignorant. Quality has little to do with where it is made and more to do with accepted tolerances from whomever is commissioning the work.
A header is a pretty complex part to build. Something as simple as removing it from it's fixture before it has cooled enough can distort it.
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | CSG Mike (04-08-2020), Irace86.2.0 (05-01-2020), mistople (04-04-2020), PulsarBeeerz (04-04-2020), Tatsu333 (07-19-2022) |
#51 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I figure the welding fixture and jigs must've been moved around a bit and warped during production. Even on the stock motor mounts, the header was hitting the underbody panel, coming too close to the passenger side sway bar bushing(melted it several times) and the bolt holes at the engine don't line up properly. I always end up having to push apart the header flanges to get it over the head studs. Luckily it hasn't ruined the head stud threads.
| The Following User Says Thank You to B T For This Useful Post: | phm14 (05-11-2020) |
#52 |
Drives: BRZ 2018
Quick question, how much of noise difference an OEM frontpipe has with and without/gutted frontpipe?
I want to gut the OEM frontpipe but due to ACE headers I believe it will be quite noisy although I have OEM catback, I like it close to factory noise levels! |
#53 | |
I'm used to italian manifacture, sorry. |
#54 | |
Drives: Crapcan
With the Nameless header on my car I have issues. Flanges are "sprung" and won't slide onto the studs without being persuaded. Also an expensive header, and US made.
#55 | |
I wonder if the JDL 4-2-1 has similar fitment issues. |
#56 | |
Drives: Crapcan
![]() It depends on so many factors. I'd say most of the common headers out there are going to be pretty dialed. The more complex, the more chance for distortion. My turbo manifold also had issues but it was a handmade 1 of 6 so the jig could have been off. I really don't hear of too many complaints across the board on any header but I am sure there are more out there then get posted.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Infinity (04-06-2020) |
| Automatic Transmission issue- dealer is not recognizing the issue, please help! | Arrex | Issues | Warranty | Recalls / TSB | 36 | 06-03-2019 05:15 AM |
| Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? | darkbluemn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-05-2018 09:49 PM |
| Injen SES Headers/ Agency Power headers | Choong86 | Engine, Exhaust, Transmission | 10 | 12-27-2013 10:51 PM |
| Headers: Has the CEL "issue" been solved? | boredom.is.me | Engine, Exhaust, Transmission | 9 | 10-20-2013 10:35 PM |
| Do all headers for the BRZ cause the CEL issue? | Oburn | Engine, Exhaust, Transmission | 19 | 05-16-2013 03:18 PM |
