Old 04-03-2020, 08:22 AM   #1
Gtouma
Drives: Gt86 2013
Slight vibration/shaking on idle after fixing some leaks
Hello,
I recently fixed the leaks of the Cylinder head , camshaft housing and cap (driver side ) by removing the engine then dismantling the parts along with the timing cover and chain ,
We placed all the parts correctly even i have replaced the spark plugs , new engine/ transmission mounts with new ones,
However now there is a light vibration which is exactly the same to the typical cold start vibration but it doesn't go away even if the car gets warm,
There is no CEL or error codes and the car drives normally fine ( i have been driving for around 1500km) and RPM is stable on idle the car just shakes ,
I have doubled checked if everything was installed correctly like all sensors , timing chain, wiring, mounts and solenoids ect. Correctly but the issue is still there,
The is 2013 stock manual transmission
75,000 km
Please i need your support,
Thank you
Gtouma is offline   Reply With Quote
Old 04-03-2020, 11:16 AM   #2
solidsnake11
Drives: brz
That's a tough one. It maybe the new mounts are transferring more vibration to the car.
When I went to a cd009 a bolt on the transmission was touching the tunnel and you couldn't here yourself think driving, I took a pry bar to that area and all the noise went away.
solidsnake11 is offline   Reply With Quote
Slight vibration/shaking on idle after fixing some leaks Gtouma Scion FR-S / Toyota 86 GT86 General Forum 7 04-06-2020 07:11 AM
Valve spring recalls, bumping idle, low mileage, leaks, dealership, OH MY.. MuseChaser Issues | Warranty | Recalls / TSB 7 11-17-2018 04:06 PM
Engine shaking/vibrations at 1700rpm - when in neutral/idle kharn83 Issues | Warranty | Recalls / TSB 9 11-07-2013 11:00 PM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 09:53 AM
Severe Shaking while in Idle from 0-5 mph ScionFR-S Engine, Exhaust, Transmission 1 10-15-2012 10:42 PM
