| Engine Swaps Discussion of engine swaps. |
Drives: FRS
2013 FRS replacement engine
Need a replacement engine as mine just spun a bearing.
What I know is that the BRZ and FRS are exactly the same engine and will directly bolt in to either cars. Can some one confirm this? My car is a 2013 FRS. I am trying to find a newer model engine, a 2015 or 2016. What I couldnt get info is if those years are direct replacement to my car. Would anyone know? I know that 2017 and up, one would need to do swap over alot of components so I am staying away from those. |
#2 |
Drives: FRS
I am considering doing the engine swap myself and been watching a lot of videos of people who has pulled the engine. I would assume that the AC line does not have to be disconnected (which I prefer). I am just not sure of this since I think I was only able to watch 1 video but it involved min. of 3 guys (2 at the motor and 1 holding on to the compressor) where the AC lines can easily be seen as being still connected. As for the other videos, there it wasn't clear weather they disconnected them and only that the copressor was on the side. An obviously, there are videos who straight up disconnects the lines. Is it really difficult to do by oneself without disconnecting them?
#3 |
Drives: 2020 GMC Canyon Denali Diesel
Very difficult to do without removing the A/C lines but could possibly be done. I've never tried it...
A 2016 engine will work, plug & play. No sensor swapping needed as long as you are using the 2016 engine harness in the 2013. You would only need to swap sensors if you were still using the 2013 engine harness.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | mrg666 (03-19-2020) |
#4 | |
Drives: FRS
#5 |
If you are using a complete engine, 2013-2016 will work as a drop in replacement. Only differences are between AT and MT versions.
#7 |
Drives: FRS
trying to get a 2015-2016 is proving to be difficult to find that is fairly priced. I am trying to avoid the 2013 model due to the valve spring issue/recall. Is the 2014 engine know for certain issues like the valve spring recall on the 2013?
#8 |
Drives: FRS
#9 |
Rust bucket enthusiast
Sometime in 2014 they revised the coilpacks and the associated harness (which would be my prime reason for not getting a 2013 engine). Other than that I don't know. 2013 is the only year that really seems to have any large issues
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Wally86 (05-06-2020) |
#10 | |
Drives: FRS
Thanks for the input Darkpira7e. I thought that the coilpacks and harness were updated on the 2015 and 2016. So some 2014s got them? how can I check/verify this on a used engine? |
#11 |
#12 |
Drives: FRS
#13 |
Drives: FRS
Is there a marking on the engine that would indicate the year model that it is coming from? If there aren't any, how is one able to tell if it is a 2015/2016 engine?
#14 |
BAE
Drives: Asphalt FRS
If you ask the seller for the VIN, you can easily identify it that way.
| Engine oil dipstick tube replacement | Alarik | Engine, Exhaust, Transmission | 2 | 01-27-2020 02:33 AM |
| Glittery engine oil after short block replacement | msaikhan | Issues | Warranty | Recalls / TSB | 17 | 08-24-2019 03:17 PM |
| Engine Replacement issue | Sloyota | Issues | Warranty | Recalls / TSB | 5 | 08-11-2019 12:38 AM |
| Has anyone here had an engine failure? Replacement cost? | Smurfette | Engine, Exhaust, Transmission | 10 | 12-02-2015 03:19 PM |
| Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** | RallySport Direct | Transmission and Driveline | 59 | 09-01-2015 01:18 PM |
