Old 03-22-2020, 07:48 PM   #1
DarkSunrise
DarkSunrise's Avatar
Bent OEM Rear Endlink
Bent my passenger rear OEM endlink. Wasn't a huge deal, replaced them with Racer X adjustables, just curious if anyone else has run into this issue. Suspension setup below:
- RCE T2's (400/400 springs, lowered ~1")
- OEM F/R swaybars
- OEM endlinks
Car has probably done 8-10 trackdays with the above setup, either on 235 RS3's or 225 BFG Rivals.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
norcalpb (03-23-2020), solidONE (03-23-2020)
Old 03-23-2020, 06:40 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I bent a stock front, think it was the left side. I can see that being more likely than the rear just by virtue of being longer. Kind of wild to see a rear bent like that. Makes you realize how much deflection is in the stock bushings.
Old 03-23-2020, 01:01 PM   #3
DarkSunrise
Yeah I always figured I'd bend a front not a rear given how short the rears are. I still can't figure out if this was from normal track use or from hitting something. Hopefully these Racer X ones are stronger.
2022 BRZ Build
2013 FR-S Build
Old 03-23-2020, 03:24 PM   #4
norcalpb
norcalpb's Avatar
Impressive. I’m replacing my endlinks this week but only because the boots are torn. I can’t believe your link bent before the fragile rubber boot tore.
Old 03-23-2020, 03:35 PM   #5
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Did you catch some good air off some curbing with your car before discovering this? And the rest of the assembly is not bent or warped or broken at all?
Intent > Content
Old 03-23-2020, 05:33 PM   #6
DarkSunrise
Haha nothing like that. The only thing that comes to mind is one time I ran over a dip in the dirt before the curbing started on the right side. So basically the wheel would have traveled down because of the dip, then immediately up because of the curbing. Was a pretty jarring hit. Everything seemed fine afterwards, but I guess not.
Yeah nothing else is bent or broken, just the endlink.
2022 BRZ Build
2013 FR-S Build
Old 03-23-2020, 08:02 PM   #7
norcalpb
norcalpb's Avatar
If the Racer X endlinks don’t work out, give Moog a shot. They are just like oem but the rod is much beefier.
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
DarkSunrise (03-23-2020), finch1750 (03-25-2020), Leonardo (03-24-2020)
Old 03-23-2020, 08:37 PM   #8
solidONE
solidONE's Avatar
Good that the bar and the mounts survived. Now you have a perfect excuse to get something adjustable. Tax-write-off-able repair expense. haha
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 03-23-2020, 10:58 PM   #9
DarkSunrise
Yeah that looks pretty solid. Thanks for the suggestion!
2022 BRZ Build
2013 FR-S Build
Old 03-25-2020, 02:12 PM   #10
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I used MOOG up front when I installed my Koni/TRD combo. Note that MOOG have grease fittings and also allow use of a spanner to hold the bolt for tightening. Others only allow use of the 6mm Allen to hold the bolt. Works fine for installion. Good luck years later when trying to remove.
Muskoka800 is offline   Reply With Quote
Old 03-25-2020, 02:29 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You don't have an issue with them hitting the inside of the tub?
I had Perrin non adjustable up front and they hit the inside of the wheel well really bad.
Old 03-25-2020, 05:21 PM   #12
norcalpb
norcalpb's Avatar
Are you saying the tightening bolt becomes seized over the years? I’ll be installing my Moogs tomorrow and I might put some anti seize on it if that’s the case.
Old 03-25-2020, 06:57 PM   #13
solidONE
solidONE's Avatar
Not related entirely, but Perrin front sway bar has fitment problems. FYI I told them about it they just sent me the same thing with the same problem.. too much play in the collars left to right.
Intent > Content
Old 03-25-2020, 07:02 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I did not know that.
My issue is the top of the link where it connects to the strut though. Went to the whiteline end link which is much narrower to solve my issue.
FS:(NJ) 13 BRZ Rear Sway Bar with Endlink zc06_kisstherain Brakes, Suspension, Chassis 2 05-19-2022 08:26 AM
Rear Endlink Bolt Sikku Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-29-2018 05:40 AM
Rear lower control arm endlink/shocks ratio adjustments Brzerker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-05-2018 01:05 AM
HIC ROOF Spoiler$100/TRD REAR bumper rep$100/slightly bent Raven hood $100 VakaGT Exterior Parts (Aero, Lighting, Etc.) 16 07-11-2016 02:49 AM
Bent rear suspension - advice needed Etomatoeman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-20-2013 01:19 PM
