Old 03-02-2020, 07:44 AM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Trunk creaking
Hello guys,
I've had this trunk rattle for over a year now, and simply cannot find how to solve it -which took a hefty toll on my mental health -. Here's what I can tell about it:
-Creaking / clicking noise, that seems to happen over low-intensity road undulations / irregularities, especially over 30mph. Not over bigger bumps.
-Definitely coming from inside the trunk (more present with rear seats down)
-Not linked to the rear seat latch (see above)
-Not an issue with the trunk release or the trunklid seal (can be heard with trunk open)
-Not linked to gas cap release cable (now firmly held in place)
-Not coming from under-trunk accessories (have been double-sided-taped and not moving anymore)
-Not the metal tab thing
-Not the trunk foam clips
-Not this, unless I did not apply enough WD40
Did anyone else experience this? How did you solve it?
Thanks!
Alex
alex87f is offline   Reply With Quote
Old 03-02-2020, 08:23 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I used to hear a ticking/clicking kinda sound from the trunk area when I first got my car. It has disappeared over time or I've become accustomed to it... Or the car has settled down as the miles have increased..
Old 03-02-2020, 09:30 AM   #3
alex87f
Meow
alex87f's Avatar
Well the car has 50 000+ miles so I don't expect this noise to go away anytime soon..
Old 03-02-2020, 09:33 AM   #4
LET HER OUT!
Dadhawk (03-02-2020), gravitylover (03-02-2020), Spuds (03-02-2020)
Old 03-02-2020, 10:15 AM   #5
alex87f
Meow
alex87f's Avatar
LET HER OUT!
I can't, people will start asking questions..
The Following 3 Users Say Thank You to alex87f For This Useful Post:
gravitylover (03-02-2020), Spuds (03-02-2020), Tcoat (03-02-2020)
Old 03-02-2020, 10:28 AM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
Get some noise cancelling headphones.. they're great!!
Old 03-02-2020, 10:41 AM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
LET HER OUT!
Or strap her down tighter.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
gravitylover (03-02-2020), humfrz (03-02-2020), Spuds (03-02-2020)
Old 03-02-2020, 12:57 PM   #8
You are SOOOOO sick!
Old 03-02-2020, 01:05 PM   #9
Hello guys,
Thanks!
Alex
Well, no, but if I did and I had tried all the things you have tried, I would take the trunk lid off the car and see if the sound goes away. That should help isolate where the sound is coming from.
Busybee (03-03-2020), ToySub1946 (03-03-2020)
Old 03-02-2020, 01:37 PM   #10
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Could it be the CHMSL rattle? (Center High Mounted Stop Light aka the spaceship in the rear view mirror.) I solved that rattle with some glue on the internal parts.
LimitedSlip is offline   Reply With Quote
Old 03-02-2020, 02:30 PM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
It's a gift.
humfrz (03-02-2020)
Old 03-02-2020, 02:37 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
If the OP takes on @humfrz advice to remove the trunk lid, then it should be done when it's raining as a bit of moisture in the trunk may help.. some expansion can help the interfaces...
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (03-02-2020)
Old 03-02-2020, 04:18 PM   #13
alex87f
Meow
alex87f's Avatar
Oh god I hope it's not that, that looks awfully complicated to remove. It doubt it is, though, as the noise gets louder when the rear seat is down, which indicates the noise is coming from the cargo area.
Well all jokes aside, it seems to be more present in dry weather. I already tried driving with the boot cracked open and the noise didn't change, so it ain't that.
Old 03-02-2020, 04:53 PM   #14
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Take a look at the wiring on the trunk lid. I suspect mine was the plate lighting.
PetrolioBenzina is offline   Reply With Quote
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
alex87f (03-03-2020), Tcoat (03-02-2020)
Creaking Chassis? weederr33 Issues | Warranty | Recalls / TSB 4 04-07-2017 09:38 PM
Sway Bar Creaking smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-16-2015 02:28 PM
Creaking during turning after coilovers? Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2015 01:51 PM
Clutch clicking/creaking Bg8780 Issues | Warranty | Recalls / TSB 4 03-25-2015 12:27 AM
Seats creaking Wes Issues | Warranty | Recalls / TSB 28 06-15-2014 07:19 PM
