Old 02-20-2020, 10:06 PM   #1
RyuHD
Drives: 2013 Subaru BRZ
(ECUTEK) Stock tune for brz?
Does anyone have a stock tune for the brz on ECUTEK, my car wont start when i have the tuned rom in it, and i couldnt save the original tune for it, ive been trying to find it for awhile now.
RyuHD is offline   Reply With Quote
Old 02-20-2020, 11:21 PM   #2
kev0
Drives: '14
Ecutek program downloads all stock maps. You just have to look for it through the program.
kev0 is offline   Reply With Quote
Old 02-21-2020, 01:29 AM   #3
tomm.brz
Drives: brz 2017 hksv2
help, ecutek update, update rom list
DarkPira7e (02-21-2020)
Old 02-21-2020, 01:58 AM   #4
steve99
Drives: FT86
You need to know which calod to flasb to car if your doing a recovery
What is year of car and is it auto or manual
Also what was your original ecu calid ?
And calid of tune you flashed
Old 02-21-2020, 11:09 AM   #5
tomm.brz
if it doesn t start usually is a wrong MAP sensor scaling
Old 02-21-2020, 11:28 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by tomm.brz View Post
if it doesn't start usually is a wrong MAP sensor scaling
This is what I was thinking when I read "no start"
OP, what are your modifications?
Old 02-21-2020, 09:00 PM   #7
RyuHD
-JDL Turbo Kit w/ UEL Manifold V2
-SKUNK2 Racing Coilovers
-AEM Boost & Air Flow Gauges
- Setrab ProLine Oil Cooler
-JDL Intercooler
-RadiumAuto Fuel Lines
-TurboSmart Blow-Off Valve
Old 02-21-2020, 09:07 PM   #8
RyuHD
yea i found it and my car supports ZA1JA01C
Old 02-21-2020, 09:17 PM   #9
RyuHD
Current is ZA1JA01c
I flashed the Same one as ZA1JA01C Rom File
2013 Subaru BRZ 2.0 limited - (MANUEL)
Which one should i flash with all these mods?
-JDL Intercooler
Old 02-21-2020, 09:21 PM   #10
kev0
Drives: '14
Current is ZA1JA01c
-JDL Intercooler
Um, what? I wouldn't flash a stock ROM at all if you have a turbo kit installed on it. You need to get a custom tune so you don't damage your engine.
The Following 2 Users Say Thank You to kev0 For This Useful Post:
DarkPira7e (02-21-2020), tomm.brz (02-21-2020)
Old 02-21-2020, 09:22 PM   #11
tomm.brz
maybe you are in confusion about this, but ecutek doesn t really provide custom tunes
you need to contact a master tuner to buy one
Old 02-21-2020, 09:44 PM   #12
DarkPira7e
DarkPira7e's Avatar
-JDL Intercooler
You definitely need to have a custom tune. Certainly you have injectors and an aftermarket MAP sensor at minimum. Both of which will cause a wildly negative impact on a car without a tune meant to accommodate them
Old 02-21-2020, 09:46 PM   #13
steve99
Drives: FT86
Ok
Now we know you flashed turbo rom if its cranks over bit wont start its most likey cause ghe map senspr installed doesnt Match map senspr scaling in tune.
If it doesnt even crank then it another problem.
Most turbo tunes will reqore a 3 or 4 bar map sensor to be installed to enavle boost monitoring and overboost failsafe and boost control
Ask tune supplier whaat map sensor is neeeded for tune
Reverting to stock tune on Ecutek stlgrym3 Software Tuning 12 10-28-2018 12:43 AM
Tuner ecutek tune back to stock? Toyota John Software Tuning 16 04-27-2016 08:08 PM
>>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! Circuit Motorsports Forced Induction 91 10-24-2013 01:07 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 03:52 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
