#29 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
Did you ever get this resolved?? I remember years ago I put Solid MM on my 3000gt. My uncle who is a great mechanic said they really had to be torqued down a lot. I had them on tight but not tight enough. Everything was great after torqueing them down with a breaker bar.
#30 | |
Wes
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | SuperTom (02-01-2020) |
#31 |
Did you happen to notice if the Perrin mounts were lighter than OEM?
#32 |
Wes
what I can do is weigh the OEM mounts and you can get in touch with Perrin meanwhile and see if the can provide you with a weight
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | SuperTom (02-02-2020) |
#33 |
#34 |
Wes
1.5 kg is as precise a measurement as I could get. Don’t have one of those small scales. Had to use a foot scale. Stepped on it with the mount and then without, subtracted the difference.
Instagram: @gt86ws
#35 |
#36 |
Wes
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | SuperTom (02-03-2020) |
#37 |
#38 |
Wes
yeah I figured the difference wouldn't be much. It's a very hefty mount
Instagram: @gt86ws
#39 |
Drives: 2015 BRZ Series Blue WRB
Thanks for the info here. I was considering the Perrin Engine mounts as well, but i think im going to go with the STI ones instead.
#40 |
Drives: Subaru BRZ
The STi are great!! I love them.. only wish it was my first mod as it made such a difference to the way the car drives... Brilliant!!!
| The Following User Says Thank You to JD001 For This Useful Post: | Jfheisenberg (06-14-2020) |
#41 | |
Drives: Subaru BRZ
#42 |
Drives: 14 BRZ Red premium
My is exactly the same with the new Perrin engine mount.
There are certain load at idle will make some not so pretty noice. But once RMP is up it gose away. I will put the car a bit more after getting tire alignment and see how they are through out the rpm range. |
| The Following User Says Thank You to j_motion For This Useful Post: | Joveen (08-10-2020) |
| Reliability concerns after major warranty engine repair? | guanqi89 | Engine, Exhaust, Transmission | 10 | 07-10-2018 09:40 PM |
| Wtb frs/brz sti engine mount | bartuc | Want-To-Buy Requests | 0 | 01-05-2018 06:17 PM |
| FS: Mtec Shift Springs / Perrin Support Mount / Perrin Shifter Mount | andy86 | Transmission and Driveline | 6 | 05-25-2017 01:26 AM |
| Perrin Trans Mount and Perrin Shifter Bushing | 00vsmcoupe | Transmission and Driveline | 1 | 03-09-2016 10:02 AM |
| sti engine mounts, oem engine/tranny mount, oem radiator | sickmint79 | Engine, Exhaust, Bolt-Ons | 0 | 08-08-2015 03:15 PM |
