Old 01-03-2020, 10:19 PM   #15
Originally Posted by solidsnake11 View Post
The picture was to show the length of the k24 compared to the fa20 but it will be a little longer since the head gasket doesn't go all the way to the front of the timing chain.
I figured as much. Looking forward to seeing your art take shape. It's inspirational.
solidsnake11 (01-04-2020)
Old 01-03-2020, 10:26 PM   #16
86MLR
86MLR's Avatar
I looked at this but sadly here in AU emmision regulations IRT engineering and registration says no.
You guys are lucky to be able to swap.
The Following User Says Thank You to 86MLR For This Useful Post:
Old 01-04-2020, 01:16 AM   #17
I'm assuming this is for track use only. Otherwise it's not kosher to swap in a powerplant that's older than the chassis for which it was originally designed. Emissions blah blah... There's more to it but that's basically the premise.
Old 01-04-2020, 03:35 AM   #18
I will grind the honda off the valve cover and put a Subaru plate on it. LOL
Shhh... I'll take your secret to the grave.
Old 01-09-2020, 12:53 PM   #19
ka-t_240
I don't know if the BRZ DI injectors have enough fuel to support what a NA K can do. Plus, I would think a new enough K that runs on DI would cost more than it would to just put AEM in or something to control the engine.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
Ultramaroon (01-09-2020)
Old 01-09-2020, 04:22 PM   #20
If I can get the ecm happy with just having one cam phaser then it will be possible to keep direct injection,
That feels like a tall order. The phasor could be simulated electrically by replacing the spool valve with a spring-loaded linear potentiometer and some clever arduino hacking.
I could pull it off, building an analog system. My coding skills, however...
Is the K24 dual DI/PI?
You might need an intake with port injection.
Ah, NVM. I get it.
Old 01-09-2020, 06:35 PM   #21
ka-t_240
No - Some are Port. Some are DI. None are both.
Old 01-09-2020, 07:50 PM   #22
If the ecu will zero the vvt it will work. I may have to send the signal to both sides of the ecm from one sensor. If I can't get it to zero I will just buy the vtc eliminator and turn it off. Its a 2.4 so it shouldn't be to lazy on bottom.
I get where you're going but each phasor is part of its own closed-loop system. No easy fakes.
Old 01-10-2020, 01:21 AM   #23
Which post is the real one and which is the fake? Lol
Just have to wait and see how the computer reacts. But I will still have the fart can vtec if I have to disable it. Maybe I could pay someone to patch the rom.
lol - that's just what the ECU is going to say.
I knew I should've quit when the first one disappeared and sent me back to the top of the page.
solidsnake11 (01-10-2020)
Direct injection/port injection explained? mike the snake Software Tuning 31 06-06-2021 07:17 PM
Is Port Injection more important when boosted? KoolBRZ Software Tuning 24 03-17-2016 04:25 AM
Best e85 oil/ meth injection Fastbrz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-26-2014 04:28 PM
ever seen fuel injection like this? carbonBLUE Other Vehicles & General Automotive Discussions 1 10-17-2012 03:17 AM
