Old 12-28-2019, 01:32 AM   #1
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
New Aftermarket Deck; Startup issues
I bought a new Pioneer NEX Deck a few months back and noticed that the Deck goes through its usual phase: Backlight ON, Pioneer Logo, Loading Screen. Usually takes about 5 second or so to get through these.
This startup phase will happen flawlessly with both 12V and Accessory modes.
However, when I go to PUSH START my BRZ the phase experiences a drain or a complete power cut to the DECK when starting the ignition.
The Ignition startup phase goes Backlight ON, Pioneer Logo, Backlight OFF, Pioneer Logo, Loading Screen. Takes about 10-11 seconds to load all of these.
I couldn't find much info on it but I'm wondering if its an issue with source of power coming from the Ignition wire. I've thought about just wiring it to a 12V source but unsure if I would lose any kind of functionality. I also have a mono block amp and a subwoofer wired to the system.
Any help would be greatly appreciated.
jbsali is offline   Reply With Quote
Old 12-28-2019, 02:07 AM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
I also have a Pioneer Nex. Mines does what your does sometimes. I haven't been able to replicate it. But to answer your question about losing any functionality, no, you won't. But you'd have to remember to turn off your deck every time you turn off the car.
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
jbsali (12-28-2019)
Old 12-28-2019, 09:33 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
could be that your battery voltage is dropping too low while starting, and it is force-rebooting the deck.
have you had your battery load tested lately?
Old 12-30-2019, 11:22 AM   #4
wparsons
wparsons's Avatar
I'm about 99% sure mine cuts power to the deck when cranking the starter, 100% audio system in a 2013 with the upgraded Pioneer OEM HU. I'll double check next time I'm in the car.
flickr
OFT E85 Startup issues CSkap21 Software Tuning 4 06-14-2019 08:18 AM
Aftermarket rear deck shelf disgruntld Cosmetic Modification (Interior/Exterior/Lighting) 18 01-29-2018 08:01 PM
Stg 2 UEL E85 B01C Startup issues BigBone3 Software Tuning 5 11-06-2015 06:43 PM
Good aftermarket Deck Unit with Navi?? taimysho0 Cosmetic Modification (Interior/Exterior/Lighting) 2 05-17-2013 08:55 AM
P8400 Aftermarket deck HELP NEEDED WITH WIRING iamkyle Electronics | Audio | NAV | Infotainment 1 01-13-2013 04:41 AM
