#183 | |
Only happy when it rains.
Drives: series.blue
Did you put your Ace header on a scale? I've been wondering the actual weight of that, and whether or not titanium headers are significantly lighter. |
#184 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
All I have is a carpeted piece of coroplast where my rear seats were, the rear seats definitely offer some sound protection
#185 | |
Besides a few things in the beginning of my build every part in here has a pic on a scale. Its Christmas so ill be nice and save you some time searching through here ![]() Ace 350 header = 9.75 lbs 350 overpipe = 3.5lbs GruppeS UEL header= 15lbs Stock header = 20.75 if your talking about those BLOX titanium headers I think they are around 5-6lbs when I was looking into them. But im sure you would need solid motor mounts as they would be prone to cracking. ACE are really the best when you consider the power gains and the weight loss as well |
| The Following User Says Thank You to SuperTom For This Useful Post: | why? (12-25-2019) |
#186 |
Did 2 quick mods today Torque Solutions Rear Cam Plate, GoFastBits idler pulleys
Cam plate -.25lbs lighter than stock ![]() GFB pulleys +.25lbs heavier than stock , But 2 of the stock pulleys are plastic all 4 of these look great quality aluminumHere is the cam plate ![]() Stock plate ![]() Installed ![]() GFB pulleys ![]() Stock ![]() ![]() Installed ![]() Then cleaned up the engine bay a bit
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | jflogerzi (12-24-2019), StraightOuttaCanadaEh (12-24-2019) |
#187 |
Got in my Cusco "soft" front sway bar from Japan, Just ordered the rear soft bar to match
~1lb lighter than stock ![]() ![]() ![]()
#188 |
Also found another bracket holding the solid brake lines to the frame. Was able to replace bracket with a zip tie to the frame + plus the area is covered by the underbody panels
.25 lbs lighter now! Current weight ~2348 ![]() ![]() ALSO ordered a bunch of Titanium bolts Titanium "Metal of the Gods" Figured out which bolts where in the $325 underhood kit, paid about 100 piecing on my own. I may be short about 4 bolts I couldn't figure out but should be a fun mod. Only expecting to save about 1/2 lb ![]()
| The Following User Says Thank You to SuperTom For This Useful Post: | new2subaru (12-29-2019) |
#189 | |
Drives: 2017 toyota 86
Your dedication to weight reduction is impressive. Curious why you still have stock air box and haven’t switched to something like a perrin cai? I never weighed mine, but id be surprised if it was anything less then 2lbs lighter. |
#190 | |
Well heard the stock +17 air box is basically the older trd box. Plus its supposed to work well with the rest of the tune. But im always looking to get lighter so im open for suggestions if there are real weights. Im finding quotes on the forums here of "this part takes off this much weight" but when I get it on the scale the difference is much less. Anyway found this titanium intake pipe, I have to see if they make if for the 17+ model years https://black-beat-motor.myshopify.c...7bf5aa63&_ss=r |
#191 | |
Unfortunately i never weighed it. and it would be a pain to get back out just to weigh, but according to anthony's "-03.300lbs | 06.388lb stock - 03.088lb FA20Club cold air intake + supplied K&N filter" You would have to get your tune adjusted and MAF re-scaled though, it could possibly at 1-2hp, i doubt it would lose any HP at-least, but you should drop roughly 3lbs off the front. |
#192 | |
No the cusco soft are about 77% the strength of stock. But since the 17+ went larger in the rear sway, the Cusco soft is going to be even softer and lighter than the 14mm stock on the older models. Softer in the rear should help with oversteer I have being so light in the ass. You may be thinking why go softer when everyone in the world goes bigger. -With my car being drastically lighter the suspension has less weight to move, so I don't need more - I already have coilovers Meister R, The are considered softer compared to most offerings, but I feel small bumps can throw the car off a bit. The stiffness of the coilovers will make up for any difference the softer sway bars may exibit. - The coilovers were really the first major mod I did before weight reductions. I haven't changed my height since then and the car has raised ~1/4 - 1/2" since then just from getting lighter -Hey softer Sways are a hair lighter! -Im wonder if some of that weight loss from the intake is from the sound snorkel removal as well. My intake is a cut open airdam, 17+ airbox/blitz filter, perrin tube. I think the only way to get lighter is a lighter than rubber tube, and a box made of Carbon Fiber instead of the plastic. I don't think theres much left to lose |
#193 | |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | SuperTom (12-30-2019) |
#194 | |
Drives: JRSC BRZ SOLD
I've ran my stock MY13 airbox, MY17+ airbox and now TRD air box. The TRD is a much different design. Its huge, I don't think it would save any weight.lol |
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | SuperTom (12-30-2019) |
#195 |
A nice breakthrough today. Finally got back to this Mishimoto slim fan setup.
The Reason I bought was to run only the passenger fan, Driver fan is really the extra fan for AC Removing one fan made both not work, same thing when trying to remove different fuses/relays. Either they both worked or were both off. Came up with running a bunch of resistors together. 2 resistors was running hot, went to 4 and it was just warm, Obviously something to monitor going forward. Lost -2.5 lbs on the Driver front! New weight 2341lbs ![]()
#196 | |
Drives: 2018 Subaru BRZ TS
| mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 06:30 PM |
| White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 03:04 PM |
| white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 02:25 AM |
| Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 08:47 PM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
