Old 12-24-2019, 08:14 AM   #183
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by why? View Post
I swear my passenger window refuses to crank up all the way. And of course the weather stripping isn't remotely tight by the back of the windows, like it was just never glued on and it is just not meant to be tight there.
Did you put your Ace header on a scale? I've been wondering the actual weight of that, and whether or not titanium headers are significantly lighter.
Mine has more to do with the adjustment points after installing the CF doors. But it really only does it if theres a big wind gust. I really need a shop manual to find out what adjustment bolt does what instead of just guessing
Besides a few things in the beginning of my build every part in here has a pic on a scale. Its Christmas so ill be nice and save you some time searching through here
Ace 350 header = 9.75 lbs
350 overpipe = 3.5lbs
GruppeS UEL header= 15lbs
Stock header = 20.75
if your talking about those BLOX titanium headers I think they are around 5-6lbs when I was looking into them. But im sure you would need solid motor mounts as they would be prone to cracking.
ACE are really the best when you consider the power gains and the weight loss as well
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
why? (12-25-2019)
Old 12-24-2019, 01:34 PM   #184
SuperTom
SuperTom's Avatar
Did 2 quick mods today Torque Solutions Rear Cam Plate, GoFastBits idler pulleys
Cam plate -.25lbs lighter than stock
GFB pulleys +.25lbs heavier than stock , But 2 of the stock pulleys are plastic all 4 of these look great quality aluminum
Here is the cam plate
Stock plate
Installed
GFB pulleys
Stock
Installed
Then cleaned up the engine bay a bit
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
jflogerzi (12-24-2019), StraightOuttaCanadaEh (12-24-2019)
Old 12-29-2019, 08:24 PM   #185
SuperTom
SuperTom's Avatar
Got in my Cusco "soft" front sway bar from Japan, Just ordered the rear soft bar to match
~1lb lighter than stock
Old 12-29-2019, 08:35 PM   #186
SuperTom
SuperTom's Avatar
Also found another bracket holding the solid brake lines to the frame. Was able to replace bracket with a zip tie to the frame + plus the area is covered by the underbody panels
.25 lbs lighter now!
Current weight ~2348
ALSO ordered a bunch of Titanium bolts
Titanium "Metal of the Gods"
Figured out which bolts where in the $325 underhood kit, paid about 100 piecing on my own. I may be short about 4 bolts I couldn't figure out but should be a fun mod. Only expecting to save about 1/2 lb
new2subaru (12-29-2019)
Old 12-30-2019, 01:27 AM   #187
86TOYO2k17
Drives: 2017 toyota 86
How does that bar feel or effect driving/handling in comparison to stock?
Your dedication to weight reduction is impressive.
Curious why you still have stock air box and haven’t switched to something like a perrin cai? I never weighed mine, but id be surprised if it was anything less then 2lbs lighter.
Old 12-30-2019, 06:37 AM   #188
SuperTom
SuperTom's Avatar
Just put it on, Should make it a bit more compliant and more grip in the front. Car get off track when hitting a bump. I really need the rear one more to keep grip in the rear
Well heard the stock +17 air box is basically the older trd box. Plus its supposed to work well with the rest of the tune. But im always looking to get lighter so im open for suggestions if there are real weights.
Im finding quotes on the forums here of "this part takes off this much weight" but when I get it on the scale the difference is much less.
Anyway found this titanium intake pipe, I have to see if they make if for the 17+ model years
https://black-beat-motor.myshopify.c...7bf5aa63&_ss=r
Old 12-30-2019, 08:55 AM   #189
86TOYO2k17
so the cusco even with it being lighter then stock, is still a stiffer upgrade over stock? so you lose 1lbs + it improves performance?
Unfortunately i never weighed it. and it would be a pain to get back out just to weigh, but according to anthony's
"-03.300lbs | 06.388lb stock - 03.088lb FA20Club cold air intake + supplied K&N filter"
You would have to get your tune adjusted and MAF re-scaled though, it could possibly at 1-2hp, i doubt it would lose any HP at-least, but you should drop roughly 3lbs off the front.
Old 12-30-2019, 10:08 AM   #190
SuperTom
SuperTom's Avatar
No the cusco soft are about 77% the strength of stock.
But since the 17+ went larger in the rear sway, the Cusco soft is going to be even softer and lighter than the 14mm stock on the older models. Softer in the rear should help with oversteer I have being so light in the ass.
You may be thinking why go softer when everyone in the world goes bigger.
-With my car being drastically lighter the suspension has less weight to move, so I don't need more
- I already have coilovers Meister R, The are considered softer compared to most offerings, but I feel small bumps can throw the car off a bit. The stiffness of the coilovers will make up for any difference the softer sway bars may exibit.
- The coilovers were really the first major mod I did before weight reductions. I haven't changed my height since then and the car has raised ~1/4 - 1/2" since then just from getting lighter
-Hey softer Sways are a hair lighter!
-Im wonder if some of that weight loss from the intake is from the sound snorkel removal as well. My intake is a cut open airdam, 17+ airbox/blitz filter, perrin tube. I think the only way to get lighter is a lighter than rubber tube, and a box made of Carbon Fiber instead of the plastic. I don't think theres much left to lose
Old 12-30-2019, 10:52 AM   #191
86TOYO2k17
Ok, good to know, that makes sense for your application. My car being an auto + supercharged makes it a good 100+lbs heavier then yours to start with, and I haven't gone nearly as extreme with the weight loss. I am probably at 2690-2700lbs curb weight. I installed cusco front and rear strut tower braces and surprisingly noticed a huge difference in stiffness and body roll so it would seem kind of redundant for my application to use a softer sway bar. but i can see how it makes sense for yours.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
SuperTom (12-30-2019)
Old 12-30-2019, 01:00 PM   #192
PulsarBeeerz
Drives: JRSC BRZ SOLD
I've ran my stock MY13 airbox, MY17+ airbox and now TRD air box. The TRD is a much different design. Its huge, I don't think it would save any weight.lol
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Old 01-04-2020, 02:26 PM   #193
SuperTom
SuperTom's Avatar
A nice breakthrough today. Finally got back to this Mishimoto slim fan setup.
The Reason I bought was to run only the passenger fan, Driver fan is really the extra fan for AC
Removing one fan made both not work, same thing when trying to remove different fuses/relays. Either they both worked or were both off.
Came up with running a bunch of resistors together. 2 resistors was running hot, went to 4 and it was just warm, Obviously something to monitor going forward.
Lost -2.5 lbs on the Driver front!
New weight 2341lbs
Old 01-04-2020, 04:04 PM   #194
Shadotracker
Drives: 2018 Subaru BRZ TS
I'm surprised that you haven't made the just the airbox out of chloroplast just yet. That is what my friend did for his STU build for his STI in autocross.
Shadotracker is offline   Reply With Quote
Old 01-04-2020, 09:47 PM   #195
SuperTom
SuperTom's Avatar
any links to his build?
I don't necessarily have to lose weight on the intake if it is effective. If im going to change my intake I want something ram air like the Gruppe M Revolution intake the shoots straight forward from the throttle body. just don't want to spend that kind of money right now.
I have a vararam on my corvette and when you get going that thing works! For the 86 it would be nice to pull in some air from the fog light holes
Old 01-05-2020, 03:28 AM   #196
RayRay88
Drives: 2017 86 860 Special Edition
The 86 already has a cold air setup oem (TRD or oem box). It takes in air from the center opening in the bumper. There's no benefit to pulling in air from the foglight openings. Something like the Gruppe M probably takes in more air, via larger ducts, but in reality you're not going to see crazy gains vs just a high flow filter and snorkel mod.
RayRay88 is offline   Reply With Quote
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 05:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 01:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-01-2013 11:45 PM
