Drives: 2014 FRS
Revs go up and stay for seconds before dropping
Hello members
Sorry if I'm asking a question that was asked before or smth but I couldn't really find a solution to it that tailored to my issue. I bought a '14 FR-S back in January 2019, took it in for Throttle Body cleaning and Fuel Injection cleaning service in Late November. After the service, every time I come to a stop and press the clutch in, the revs go up and stay between 2K-3K for like 2 seconds before dropping, the car also tends to hold the gas for me when I drive as it keeps revving when I let go of the throttle. Legit makes my manual feel like an unpredictable auto. Car is completely stock too!! Anyone have any solutions to this or can suggest some solutions ? I am about to call and grill Don Valley Toyota ![]() UPDATE: Disconnected the battery for 30 minutes, let the car relearn and the problem went away. A special Thank you to all those involved in this thread. Last edited by Bardia; 01-06-2020 at 10:22 AM. |
#2 |
Drives: 2017 Subaru BRZ
Mine also does this im here to see whats going on too.
Sent from my SM-G960W using Tapatalk |
#3 |
Drives: 2014 FRS
#4 |
No mine happened on its own but mine is boosted.
Mine happens in first gear with the clutch in. If im behind someone on a stop sign i dont put it in neutral i just stay in first gear but the rpms stay at 1.5-2k before it drops. Sent from my SM-G960W using Tapatalk |
#5 | |
Drives: 2014 FRS
#6 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
My advice is to grab a scanner and do a code clear. You may not have codes but doing a clear will reset adaptive values. If you don't have one disconnect the battery and reconnect after 30 minutes.
My thought is that your engine computer is running on old adaptive values from before throttle body cleaning and is having trouble re learning. With less carbon build-up there would be more airflow at any given percentage of throttle opening which would make sense given your symptoms. More air, more rpm. The shop should have done this when they did the work but maybe didn't.
Work Hard. Play Hard.
2016 Oceanic |
| The Following 3 Users Say Thank You to ActionMaxon For This Useful Post: |
#7 |
I reckon the linkage to the carburetor is binding. Oil up the pivot points.
Oh wait, where am I - ![]() Oh, OK, here I am. - ![]() I'd suggest you go with ol @ActionMaxon 's suggestion. humfrz |
#8 |
Rice King
It's definitely an overflow blinker fluid reservoir. Disconnect the exhaust, open your trunk and drain blinker fluid.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#9 |
Drives: FT86
Check for intake leaks ie check all intake hoses especially ones under intake manifold.
Remove intake hose, with ignition on but engine stopped have a mate press accelerator to floor then release check the throttle butrerfly moves freely full range Disconnect battery for 30 minutes reconnect, start car let it idle with no throttle input for at least 2 minutes. Check again for fault |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | humfrz (12-09-2019), Ultramaroon (12-10-2019) |
#10 |
| The Following User Says Thank You to humfrz For This Useful Post: | Jordanwolf (12-09-2019) |
#11 | |
Drives: 2014 FRS
#12 | |
Drives: 2014 FRS
It is actually funny though, feels like an auto |
#13 |
Drives: 2014 FRS
[QUOTE=steve99;3281813]Check for intake leaks ie check all intake hoses especially ones under intake manifold.
Remove intake hose, with ignition on but engine stopped have a mate press accelerator to floor then release check the throttle butrerfly moves freely full range Disconnect battery for 30 minutes reconnect, start car let it idle with no throttle input for at least 2 minutes. Check again for fault[/QUOTE Hmm thank you, Imma follow yours and actionmaxtons solution, hopefully it all comes out fine. Good part is that it is in storage for the next two months. |
#14 | |
Rice King
[quote=Bardia;3281871]
Glorious Honda.
| OFT - Revs not dropping to idle after WOT and letting off gas | justinco | Software Tuning | 14 | 01-11-2017 10:38 PM |
| Where do you keep your revs? | ScionFrsFan | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 06-11-2015 01:07 AM |
| What's causing slow dropping revs? | hchi rku | Engine, Exhaust, Transmission | 15 | 03-08-2014 07:39 AM |
| 2.5L with lower revs/more torque, or 2.0L with higher revs? | Superhatch | Engine, Exhaust, Transmission | 124 | 08-28-2013 01:20 PM |
| 0-60 in 6.1 seconds? | SUB-FT86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 57 | 01-04-2012 11:14 PM |
