| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Give me a narrower tyre with better compound.
I'm at 270hp-280nm running 235 RE003 (Indy 500) on a 8" rim. I had better grip with a 215 RS4 on the 8". The Indy 500's are slightly better in the wet than the RS4's, and I got them on sale, BUT, it was an unfortunate compromise which I won't do again. Next will be 225/45 or maybe 235/45 Hankook RS4, you cannot beat them for a bang for your buck tyre.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#30 |
Drives: BRZ 2018
My personal, subjective experience is:
when you reduce unsprung weight by about 6lb (per corner), the perceived gain in performance (acceleration, ride quality, handling, etc) is slight but noticeable; and when you increase unsprung weight by about 6lb (per corner), the perceived loss in performance is much bigger and intolerable. As my wife would say:this is not the car I have known all along. |
#31 | |
Drives: '23 BRZ
Even flywheel mass reduction isn't all that effective as far as outright acceleration goes. Bigger difference is in shifting |
#32 |
Drives: 2017 toyota 86
https://grassrootsmotorsports.com/ar...really-better/
Interesting article. The gist is the lighter the vehicle and the slower the speed the more weight reduction and especially rotational weight reduction makes a bigger difference as the force required to rotate the mass becomes a larger percentage of overall force needed to accelerate, and same goes for lower hp cars, the force needed to rotate the mass becomes a larger percentage of available force output. So rotational weight reduction on a 2000lbs car with 150hp accelerating from 20-60mph will have a substantially bigger difference then a 4000lbs car with 300hp accelerating from 60-100mph. |
#33 |
Wheel rigidity > wheel weight.
Also, lose weight on your tires if you're concerned about weight! Wheel design can change inertia without changing weight, and inertia is what you're really fighting! |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#34 |
#35 |
Drives: 2016 Scion FRS
Related to that, I'm always blown away by the difference in weight of a full tread tire versus the same tire shaved or worn down.
#36 | |
Wes
If they were going to always put a HEAVY tire on it... oh well.
Instagram: @gt86ws
#37 | |
Drives: 2017 BRZ
I think it's overlooked because the data is mostly unavailable. |
| The Following User Says Thank You to gtengr For This Useful Post: | Racecomp Engineering (12-05-2019) |
#38 | |
Drives: jrsc_brz
| The Following User Says Thank You to HaXx For This Useful Post: | Leonardo (12-06-2019) |
| Lets talk tickets :) | t.chk | NY / NJ / CT / PA | 78 | 04-26-2014 12:16 PM |
| Lets talk tires... | frs10 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 10-04-2013 06:21 AM |
| Lets talk rev limiter. | Method | Engine, Exhaust, Transmission | 7 | 06-13-2013 10:20 PM |
| Lets talk exclusivity | whitejdm | BRZ First-Gen (2012+) — General Topics | 33 | 02-15-2012 02:17 PM |
| Lets talk weight | KaliKev | Scion FR-S / Toyota 86 GT86 General Forum | 63 | 09-12-2011 01:05 AM |
