Old 11-27-2019, 10:17 PM   #1
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
DTC 1231 Steering Angle Sensor
I installed an aftermarket steering wheel, and I snagged the clock spring when I pulled off my wheel, which I knew I needed to avoid from a prior disassembly when I wrapped my OEM wheel. Oh well. The assembly unclipped and unwound. I was able to reassemble the clock spring, and I reinstalled everything. I got the abs and slip lights coming on, so I used a Techstream to do a zero point calibration, which eliminated the lights. I thought I was home free, but now when I turn the wheel all the way to the right (not the left) the lights come back on. I have no clue why. I get DTC 1231 which is the steering angle sensor, but I really don't understand if that sensor needs replacing because it was the clock spring that unwound. It is odd.
I was looking online and the clock spring and the steering angle sensors are two different pieces, and they are pretty expensive. What's worse is that I have no guarantee that replacing the sensor/s will fix the problem. All the harness wires and clips look fine and feel solid, but there is clearly some issue with the connection or something.
Does anyone have any ideas?
I am not too familiar with Techstream. I just got it for this issue (eBay version). When I look at the diagnostic information page from the DTC there is just a lot of numbers that I am clueless about. I could post a screen capture if it helps. All I have read online is people having a similar issue without it getting resolved, some of whom did wiring checks only to find odd readings with voltage, resistance, or odd values with the angle sensor.
Old 11-27-2019, 10:34 PM   #2
Irace86.2.0
https://www.certifiedsubaruparts.com...iABEgKiRPD_BwE
$248
Clock Spring aka Steering Roll Connector
https://www.certifiedsubaruparts.com...3196CA030.html
$179
I have found aftermarket (cheaper) replacements for the clock spring that are not hundreds of dollars, but not for the steering angle sensor.
C1231 - Steering Angle Sensor STS-V Issues | Warranty | Recalls / TSB 6 01-13-2023 10:13 AM
Steering angle sensor reset Brzxton Electronics | Audio | NAV | Infotainment 3 08-16-2019 02:40 PM
Can anyone help me out with a Techstream steering angle sensor reset? norcalpb Northern California 4 08-15-2019 07:02 PM
Anyone local with a tech stream that could help? Steering angle sensor issue derrickgoes Southern California 2 06-19-2018 12:05 AM
Which shop can zero the steering angle sensor and yaw sensors after alignment? krayzie CANADA 5 09-09-2015 07:28 PM
